Old 16-May-2013, 1:57 AM   #1
meazz12
Better antenna suggestion
I am using ClearStreamâ„¢ 2V Long Range UHF/VHF DTV Antenna with a Antennas Direct CPA-19 preamp installed with a 2 way splitter going to 2 tvs. This antenna is installed in my back fence with in a PVC poll almost 15 to 18 foot tall.
There are couple of channel, for example WPBA-BT 30.1 is iffy. On a very bright sunny and I can get the channel but most of the time I have no-signal issue. This is very frequent and I would really like to get this channel. If I play with the antenna angel, i may get somewhat better reception but I lose many other stations. My antenna is at 260 degree magnetic compass.
Is there a better or more powerful antenna that you can recommend?
meazz12 is offline   Reply With Quote
Old 16-May-2013, 5:08 AM   #2
TVFR from your earlier thread
Previous thread: http://forum.tvfool.com/showthread.php?t=8926
Is this still a valid TV Fool report for your situation http://www.tvfool.com/?option=com_wr...073bfe839c0a6c?
Old 16-May-2013, 12:45 PM   #3
meazz12
Yes, this is still valid.
Old 25-May-2013, 5:27 PM   #4
meazz12
Nothing out there stronger than the antenna I have now?
Old 25-May-2013, 11:46 PM   #5
Install a Winegard HD7698P antenna aimed at about 235 degree magnetic compass direction.
