Old 18-Apr-2013, 11:39 PM   #1
Decivox
Question Help with antenna selection
Hello all,
I am wondering what the best antenna selection would be for my situation:
http://www.tvfool.com/?option=com_wr...1dda0a9288dbd2
I am on the 4th floor of an apartment and my window faces north east. I can position the antenna from my balcony to face south east, but there may be a tree kind of obstructing the line of sight once the weather gets warmer and the leaves grow.
I am only feeding one TV and it will be maximum 10 feet away from the antenna.
I saw a website that recommended the CM4228.
This is located in Ottawa if anyone is wondering.
Decivox is offline   Reply With Quote
Old 19-Apr-2013, 2:57 AM   #2
So that I can recommend a antenna/s.
What is the apartment building construction??
Wood with wood or vinyl siding and composition asphalt shingles is the best for indoor reception.
The following is a Non Complete list of building construction that will further reduce and block Tv reception.
Concrete , concrete blocks , concrete roof tiles , bricks , rocks , metal siding , metal roof , metal backed insulation , radiant barrier metal backed insulation , metal doors , solar panels , and etc. .
Old 20-Apr-2013, 7:00 PM   #3
A small all channel outdoor antenna such as the Winegard HD7000R is ideal if you are able to mount and point it NE with out obstructions in the way.
Depending on the building construction, an indoor antenna may perform well for you. The TERK HDTVi (not the HDTVa) would be a worthy option.
Old 21-Apr-2013, 1:26 PM   #4
Decivox
Thanks for the responses everyone!
The building contstruction is steel, brick, and concrete. I am unsure of the roof - I am on the 4th floor and the building is 15 floors.
Thanks for the recommendations. I just wanted to add I got my hands on a Wineguard SS-3000 to test indoor reception and I get a few channels. CBC comes in fine, along with a few others of the french channels. OMNI, CTV, and City are really flaky though depending on weather.
Old 21-Apr-2013, 5:15 PM   #5
It sounds as if the building construction is going to force you to mount outdoors or at a window. The concrete and steel are notorious for making reception difficult indoors.
Old 21-Apr-2013, 9:28 PM   #6
Indoor/inbuilding and attic Is/Are Not a Tv reception friendly environment and Never Will Be a reception friendly environment.
The building construction is.
Multi-path/reflecting-tv signals bouncing all around -> not good for Tv reception.
Absorbing -> not good for Tv reception.
Blocking -> not good for Tv reception.
________________________________________________
For better reception of the , North/North East Group , of Digital Broadcast Tv stations/channels.
CBOFT , French language tv channel.
CBOT , CBC.
CIII , GTN.
CJOH , CTV.
CIVO , TQ.
CICO , TVO.
CHOT , TVA French.
CHGS , French Tv.
Install a Winegard FVHD30 antenna in/at the North East , Window.
Aimed at about 349 degree magnetic compass direction.
Here is how to aim antenna , http://www.kyes.com/antenna/pointing/pointing.html.
And run a coax to the Tv location.
The Digital Tv reception of the North East Group of Digital Tv stations/channels are Strong Signal Strength.
Do Not install any type or kind of antenna system amplifier.
A antenna system amplifier will Over Load and be the cause of bad or no reception of some channels.
For better reception of the South East Group , of Digital Broadcast Tv stations/channels.
CHRO , CTV 2.
CHCH , IND. and Movies.
CITS , Religion.
CJMT , OMNI 2.
CFMT , OMNI 1.
CITY , CITY.
Install a Winegard FVHD30 in/at the balcony window or out on the balcony.
Aim the FVHD30 antenna at about 149 degree magnetic compass direction.
The Digital Tv reception of the South East Group of Digital Broadcast Tv stations/channels are Strong Signal Strength.
A antenna system amplifier will over load and be the cause of bad or no reception of some channels.
At the Tv location , a A/B Remote control antenna switch will be connected to the 2 Separate antenna coaxes.
The Remote control A/B antenna switch will change from one antenna to the other antenna.
Do Not try and eliminate the A/B antenna switch.
Do Not connect both antennas on to one coax at the same time.
Both antennas on the same coax at the same time will produce Bad Reception.
The 2 antennas will cross talk and reception will be much worse.
Here is a Remote control A/B antenna switch.
http://www.mcmelectronics.com , #32-4425.
http://www.saveandreplay.com , has the same Remote control A/B antenna switch.
_______________________________________________________
http://www.saveandreplay.com.
http://www.amazon.ca.
______
http://www.solidsignal.com.
http://www.amazon.com.
For this 2 Separate antennas with a A/B antenna switch to work , the Digital Tv must have the , Channel/Rescan/Scan/Add Feature that makes it possible to put more channels into the tuners memory with out erasing the first channels that are scaned into memory.
Some Digital Tv's - Do Not.
A note , CRC-DT-channels 46 , 1-2-3-4 , and , CRC-DT-1 channel 51 , are Test channels , used for testing Digital Broadcast Tv transmission and reception systems.
Old 23-Apr-2013, 1:24 PM   #7
Decivox
CBOT , CBC.
CIII , GTN.
CJOH , CTV.
CIVO , TQ.
CICO , TVO.
CHOT , TVA French.
CHGS , French Tv.
CHRO , CTV 2.
CITS , Religion.
CJMT , OMNI 2.
CFMT , OMNI 1.
CITY , CITY.
______
Wow, very informative. Thanks!
Too bad the FV-HD30 has a 2-4 week lead time from Amazon.ca
