Old 28-Mar-2013, 12:15 AM   #1
darkmatter
Setup help for father in-law
Here is the tvfool report.
http://www.tvfool.com/?option=com_wr...1ddab3bbe4a8b3
He is interested in getting only the locals (16,22,28,44 and 56) but if possible I would like to get him (64,38 and 60) too. He lives in a wooded area. All the locals are LOS at 250 degrees so I don't think that they would be that big of a problem. Channel 64 and 38 are both 2 Edge and at 290 degrees. Channel 60 is 2 Edge and at 194 degrees. I was thinking one of these three antennas but not sure because of the tree coverage. At most he will be going to 3 tvs more then likely only one
Winegard hd7697p
Winegard hd7698p
Antennas Direct DB4e with a high vhf antenna addon
Thanks Rich
Last edited by darkmatter; 28-Mar-2013 at 2:40 AM. Reason: forgot to add something
darkmatter is offline   Reply With Quote
Old 28-Mar-2013, 4:01 AM   #2
The warning at the top of your TVFR, "WARNING: Address was only resolved to zip code level and might not be that close to your actual location. For more accurate results, try entering a specific address or coordinates." makes any suggestions far more speculative. Can you provide a more accurate TVFR?
Old 28-Mar-2013, 4:15 AM   #3
darkmatter
I just tried again and got the same results. I don't know what to put down for his cordinates. All I know is he lives in a community and his mailing address is different then his physical address. The address I tried is his physical address. His mailing address is a po box. I tried a different town called Lake aerial and got better results.
http://www.tvfool.com/?option=com_wr...1dda8591628f51
Last edited by darkmatter; 28-Mar-2013 at 4:21 AM. Reason: tried something different
Old 28-Mar-2013, 12:44 PM   #4
oakleyhoma
You might ask him for an address near his house, then if you're familiar with his house/neighborhood: go to tvfool.com select online tv maps (believe it is). Then choose a tab on right: map, terrain, satellite - whichever works best for you. Zoom in/out and try to find his street/location. I like the satellite, since you can plop your antenna down exactly where you want it (if you know how it would look on the sat photo). Adjust height for height you think it will be. Make radar plot and post it.
oakleyhoma is offline   Reply With Quote
Old 28-Mar-2013, 1:09 PM   #5
darkmatter
I found his community online and it is located in Lake Ariel so the second tvfool report should be accurate. Not as easy as I orginally thought. cause pretty much everything is at least 1 edge from him. Also he has alot of tree coverage. Plus side all the locals seem to be in the same direction and I know that they are on top of a mountain right near the ski slopes.
Old 28-Mar-2013, 5:31 PM   #6
darkmatter
I did type in his physical address and used Lake Ariel zipcode for the second tvfool report so this one should be good.
Old 28-Mar-2013, 7:53 PM   #7
The 'wooded area' can be a challenge. (I'm currently working on getting my antennas up to 80' or higher due to trees, and that's with nearly 100% LOS conditions @ 30' for everything withing 35 miles.)
In you father-in-law's case, even if not for the trees, I would go big. Any of the high gain UHF antennas such as the Antennas Direct 91XG, Winegard HD9095P, or the 8-bay panel antennas would be appropriate. I would also add a High-VHF antenna such as the Antennacraft Y10713 or Winegard YA1713 to chase after real CH-11 & Ch-13. If you opt for the H-VHF, you'll need a UVSJ. In either case, you'll need a preamp such as the Antennas Direct PA-18 or Kitztech KT-200-COAX TV
Perhaps your most valuable 'investment' will be the selection of mounting location. Avoid aiming into nearby trees if at all possible.
Old 28-Mar-2013, 8:07 PM   #8
darkmatter
Ok thanks. The trees where he is are pretty dense and high so getting around them or over them would be a challenge if even possible. So you think 2 seperate antennas would be better then say 1 winegard hd7698p. I see that the one you recomended has a couple more elements for Uhf. Is it harder to get Uhf or Vhf thru trees.
Old 28-Mar-2013, 8:49 PM   #9
Install a DB4e aimed at about 365 degree magnetic compass direction.
For reception of the UHF channel Digital Tv stations/channels.
____
Install a Winegard YA1713 aimed at about 197 degree magnetic compass direction.
For reception of.
WBPH-TV REAL VHF Digital channel 9 , virtual number (60.1) , Religion.
______________________________
Connect the DB4e Uhf antenna and the YA1713 Vhf antenna together with a , Antennas Direct , EU385CF-1s. UHF antenna / VHF Antenna , Combiner.
Connect the DB4e antenna to the UHF connection of the combiner.
Connect the YA1713 antenna to the VHF connection of the combiner.
The remaining connection of the combiner connects to a , Antennas Direct CPA-19 preamp.
____________
For 1 Tv connected use No amplifier.
For 3 Tv's connected use a HFS-3D , 3 way splitter.
Buy HFS splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com
_______________________________
As always , trees and tree leaves , plants and plant leaves , do a good job of , absorbing , multi-path reflecting , blocking , OTA=Over The Air , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
___________________________________________
Here are some Strong and Sturdy antenna mounts.
http://www.ronard.com/909911.html , install the 5 or 7 foot tripod antenna mount.
http://www.ronard.com/34424560.html , install the #4560 eave antenna mount.
http://www.ronard.com.
http://www.solidsignal.com.
http://www.amazon.com.
Old 28-Mar-2013, 10:01 PM   #10
Both UHF and VHF are absorbed (converted to heat) and reflected by foliage. UHF is affected a bit more.
As teleview's aiming advise suggests, separate antennas allow you to point at signals from separate directions.
Old 29-Mar-2013, 2:10 AM   #11
darkmatter
Ok thanks guys I will see him this weekend and will find out what he wants to do.
Old 1-Apr-2013, 5:22 PM   #12
darkmatter
Please correct me if i'm wrong. I was looking at the tvfool report again and I noticed something. Real channels 22 WNEP ABC, 25 WYOU CBS, 28 WBRE NBC, 36 WSWB CW, 44 WVIA PBS, 47 WOLF FOX, and 49 WQPX ION are all on the UHF spectrum. Also they are all at 357 degrees. Rather then using 2 Antennas (UHF and VHF) do you guys think I could just get 1 big and powerful UHF one pointed at 357 degrees to power thru the dense trees?
Old 1-Apr-2013, 6:38 PM   #13
You're absolutely right, looking to the NNW only WBNG operates in the VHF band.
The UHF antennas mentioned in post #8 of this thread are 'big and powerful UHF' antennas. You'll need to try one to know how much impact the trees make in this case.
Old 1-Apr-2013, 11:04 PM   #14
You are correct.
I changed my recommendation to reflect the better reception to the , north/north west at about 357 degree magnetic compass direction.
I think would be better to up grade the DB4e to a DB8e for better UHF reception through the trees.
