Old 27-Mar-2013, 3:54 PM   #1
ripp1202
what is the best antenna for this address 30 foot tower
http://www.tvfool.com/?option=com_wr...1dda40f3e0c3c0
ripp1202 is offline   Reply With Quote
Old 27-Mar-2013, 8:14 PM   #2
It looks as if you'll get a more complete line up of programing if you concentrate on the group of stations to the SE at about 155° compass.
I would go big, a Winegard HD7698P equipped with an Antennas Direct CPA-19 preamp.
An alternate system would be an Antennas Direct 91XG and an Antennacraft Y10713. The two antennas can be combined with a UVSJ. I'd still opt for the CPA-19 with this option.
Old 27-Mar-2013, 8:58 PM   #3
ripp1202
would you put a rotor on it? thanks
Old 27-Mar-2013, 9:57 PM   #4
If you have only one TV, and it can 'add-scan' or it permits manual direct entry tuning of real channel numbers, then a rotator may be of use to you.
If you have more than one TV, a rotator is going to be hated by the viewer who does not get to control it.
Another problem arises if you have a TV that only tunes stations found by scanning. This problem is worse if the TV forgets all previous scans each time a new scan is run. A full rescan each time you turn the antenna is an agonizingly slow process.
I would opt for a main antenna system using fixed aim. If you want a DX antenna that you can look for off angle and distant out of market signals with, add a second antenna system that cables separately to a set top box tuner, preferably one that can be manually configured or at least accepts 'add-scan' entry of new channels.
http://forum.tvfool.com/showthread.php?t=8275
