Old 13-Mar-2013, 4:37 PM   #1
dudleyhd
what antenna is best for my area
hello i was wondering if any one could tell me what the best antenna amplifier combo i would need to buy to get the most channels in my area and if i need a rotator thank you james
here is my tv fool report
http://www.tvfool.com/?option=com_wr...1dda98998129eb
dudleyhd is offline   Reply With Quote
Old 13-Mar-2013, 6:01 PM   #2
For reception of , Many , many , many , many , many , many , many , many , many , many , many , Digital Tv stations channels , the groups of Digital Broadcast Tv stations/channels to the west and east with one antenna aimed one direction.
Install a Winegard HD7084P antenna with a Winegard HDP-269 preamp aimed at about 283 degree magnetic compass direction.
Here are some Strong and Sturdy antenna mounts.
http://www.ronard.com/909911.html , install the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. install the #4560 eave antenna mount.
http://www.ronard.com.
http://www.solidsignal.com.
http://www.amazon.com.
http://www.www.winegarddirect.com.
_____________________________
For coax that is outside exposed to the weather/water , use the the coax that has the Compression type connectors on the ends of the coax , not the Old crimp type connectors.
To seal outside connections use , http://www.coaxseal.com
________________
For 1 Tv connected use a use No splitter.
If installing on the building , Install HD7084P antenna Above The Roof in such a manner that the roof and building are not blocking reception to the , west , east , north east.
As always trees and tree leaves do a good job of , multipath/reflecting , absorbing , blocking , OTA=Over The Air , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and building.
It is best to install the HD7084P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The Tv/s Must Channel Scan for the Digital Broadcast Tv stations/channels , often named the 'Air Channels' or ' Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the TV Setup Menu and select , 'Air Channels' / 'Antenna Channels'.
Old 13-Mar-2013, 8:07 PM   #3
dudleyhd
thank you teleview i appreciate the help judging by my report am i going to get to see all of channels listed or is it gonna end up be 2 or 3
