Old 3-Mar-2013, 3:13 PM   #1
kelk10
help with antenna selection and position
http://www.tvfool.com/?option=com_wr...1dda2ee7586342
I am looking for some help as to what antenna to buy and where to place it. I would like to get stations from the two nearest cities. One is north northeast and the other is to the south. Report link above.
I would also like to keep the antenna in the attic if possible. Otherwise on my eaves which is 20ft high. There is a mature tree on the other side(south) of my house.
If at all possible I would also like to get WB NS (10.1) which is to the east. (Browns Games).
Thank you very much in advance.
kelk10 is offline   Reply With Quote
Old 4-Mar-2013, 12:19 AM   #2
elmo
WBNS 10 is gonna be tough to pull in. You'll need some serious antenna to get anything reliable from it, from what I can tell. I'd suggest waiting to hear what some of the experts here say about it being possible.
What I can tell you is that you're wanting stations from 3 different directions. A good long range antenna on a rotor might be what you need. If a rotor doesn't suit your needs, you'll need a multi-antenna setup with an A/B switch.
Those channels to the NE are a piece of cake. A small UHF/VHF antenna could do it, like the ANT-751 or HD7000R. That much, I am pretty certain of.
The southern channels, besides being a fair distance away, have some terrain in the way. From your attic with a mature tree in that direction, odds are not in your favor for a reliable signal. You'll want something capable of going longer than the ones mentioned above, like a Winegard HD 7698P, or maybe an all UHF like the, Antennas Direct 43XG since no VHF reception required (if using an AB switch)
To go after all 3 directions on a rotor, you'd probably want the Winegard HD8200U. And it will want to be on top of the house.
Old 4-Mar-2013, 2:30 AM   #3
WBNS -->Will Not<-- be Reliably Received with the antenna at 20 feet above ground.
To see if signal strength improves at higher antenna heights , make 3 more tvfool radar plot reports , 40 , 60 , 100 , feet antenna heights.
Old 4-Mar-2013, 4:07 PM   #4
Antenna rotators Are Not channel surfing friendly , must wait for antenna to rotate , and there will be Domestic Situations about the direction the antenna is aimed.
For reception of the Lima and Dayton areas Digital Tv stations.
Install 2 Separate antenna systems.
2 Separate antenna systems with Remote control A/B antenna switches is Channel Surfing Friendly.
____________________________________
Antenna system A.
For reception of the Lima area Digital Tv stations/channels , above the roof in such a manner that the reception is not blocked by the roof and house to the , north east , install a Winegard HD7694P antenna aimed at about 35 degree magnetic compass direction.
Try reception with no antenna system amplifier.
For 2 Tv's connected , use a HFS-2D , 2 way splitter.
_______________________________________________________________
Antenna system B.
Above the roof so that reception is not blocked by the roof and house in the direction of south.
Install a Channel Master CM4228HD antenna aimed at about 178 degree magnetic compass direction.
Try reception with out a antenna system amplifier.
For to Tv's connected use a , HFS-2D , 2 way splitter.
________________________________________________________________
Here are above the roof antenna mounts.
http://www.ronard.com/909911.html , use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html , use a #4560 eave antenna mount.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal buy typing the word ronard in the solidsignal search box or buy from ronard.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.channelmasterstore.com.
_____________
Use Remote control A/B antenna switches , http://www.mcmelectronics.com , #32-4425.
At each Tv location.
