Old 2-Mar-2013, 5:21 PM   #1
Sunny
Help with improving reception.
Hi,
I currently have a winesgard FVHD30 located 12ft up in my garage rafters.
I can get channels 8,43,49,59 and sometimes 26. I tried a Clearstream 4
To try to get CBS, NBC and fox that are north east, but nothing.
What would it take to get these additional channels.
http://www.tvfool.com/?option=com_wr...1ddad000e51a6c
Sunny is offline   Reply With Quote
Old 2-Mar-2013, 6:59 PM   #2
As always , Attics Are Not a reception friendly environment and Never Will Be a reception friendly environment because of signal attenuation and multipath/reflections - signals bouncing all around.
Install the FVHD30 , Above the Peak of the roof in such a manner that reception is not blocked by the roof and garage and roof and house in the directions of , north east , south east , south , south west.
Aim the FVHD30 at about 25 degree magnetic compass direction.
Here is how to aim antennas , http://www.kyes.com/pointing/pointing.html.
_______________
Install a Antennas Direct CPA-19 preamp.
_______________
Here are places to buy antenna system componets and etc. , http://www.solidsignal.com , http://www.amazon.com.
As always , trees and tree leaves do a good job of , multipath/reflecting , absorbing , blocking , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the FVHD30 at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house. The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital tv's will automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select 'Air Channels' / 'Antenna Channels'.
_________
Digital Broadcast Tv Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
Do a Double Rescan.
Old 2-Mar-2013, 7:53 PM   #3
Sunny
teleview,
Thanks for the quick reply. When I had the clearstream 4, I tried it outside
20 ft up on a pole trying to get CBS, fox and NBC which are north northeast.
All three are pretty much inline, but I couldn't get and signal for any of them.
And they are not that far away.
I thought the clearstream would be better than the FVHD30.
Do I need a different antenna?
Old 5-Mar-2013, 1:47 AM   #4
Sunny
With the FVHD30, will I be able to get abc, NBC and fox stations to the north northeast or do I need a different antenna?
Old 5-Mar-2013, 3:19 AM   #5
Install a Antennas Direct Clear Strem 2 Complete UHF/VHF antenna aimed at about 25 degree magnetic compass direction.
http://www.antennasdirect.comClearSt...VHF-Combo.html.
Remove the Reflector Screen from the CS2 Complete antenna.
The reflector screen is not the UHF reception loops.
The reflector screen is not the VHF reception rods.
The reflector screen is a screen , remove the reflector screen.
With the reflector screen removed the CS2 Complete antenna will receive at the front of the antenna and back of the antenna.
Your location has receivable Digital Broadcast Tv stations/channels in the directions of , north east , south east , south west.
_________________
Use All New coax cable for outside coax. <--Important.
Use the coax that has the compression type connectors on the ends of the New Coax. <--Important.
Do not use the Old type of connectors on the coax that are the crimp type connectors.<--Important.
Only use New Coax.<--Important.
Install the CPA-19 preamp.
Use All New coax.
Important<--> As a Test to prove reception the coax that goes from the preamp to inside the house Will Be 1 Loooong New coax.
Run the New Loooong coax through a open door or window direct to the location of the Tv.
And connect the New Loooong coax to the preamp power injector and the preamp power injector is connected to the preamp power supply , and the New coax to the Tv from the power injector is connected to the Tv.
NO Splitters. NO coax ground block connector. NO couplers.
Use ALL New Coax.
______
Digital Broadcast Tv Tuners can develop - Digital Glitches - that are not cleared out with a simple channel scan.
Do a Double Rescan.
http://www.dtv.gov/rescan.html..
______________
