Old 26-Feb-2013, 5:54 PM   #1
Emu25
Rear reflector on UHF antenna
Anyone with experience in UHF antennae please comment.
I am about to conduct a test using a combo UHF/ VHF Yagi antenna. If I remove the angled rear reflector on the UHF end, will this increase the UHF rearward gain? Will this come at the expense of forward gain?
(I am thinking this may be a way to get signals 180 degrees opposed.)
Thanks all in advance.
Emu25 is offline   Reply With Quote
Old 26-Feb-2013, 6:13 PM   #2
Yes removing the angled , < , UHF reflector will allow more reception from other directions to be received by the antenna , and yes removing the reflectors will reduce forward gain.
If the Tv transmissions are strong in the forward direction , thats Ok.
All experimental ways to get reception , so is Ok.
The angled reflectors are easy to put back on with some bolts and nuts.
Old 26-Feb-2013, 6:41 PM   #3
If you haven't already, you can also experiment with aiming the antenna at the weaker signal source(s). In some cases, you'll be able to improve the weak signal reception while still maintaining adequate reception of the stronger signals.
