Old 25-Feb-2013, 8:50 PM   #1
jd1879
HDTV ota antenna tips or recomendation
I added the info I received when putting my address in. Looking to cut direct tv. Antenna would be mounted at same high point (20ft) where dish is now. Any help would be appreciated.
http://www.tvfool.com/?option=com_wr...1dda033219c51e
jd1879 is offline   Reply With Quote
Old 25-Feb-2013, 9:52 PM   #2
Your TV Fool report looks very good. Do you have trees or neighboring buildings close in (between SW & SE)?
How many tuners do you plan to connect?
Old 25-Feb-2013, 10:00 PM   #3
jd1879
I have tall trees about 200 feet out when looking in between the 179 degree and 213 degree range and my towers are not more than 37 miles away with most at 20. Mainly just want the major networks. I was able to get them intermittently with variable locations with an interior antenna from radio shack.
Old 25-Feb-2013, 11:45 PM   #4
jd1879
apologies. 4 max but likely just 3 tvs.
Old 26-Feb-2013, 2:41 AM   #5
If not for the trees, I would suggest a smaller antenna. But the Douglas Fir, Cedar and Alder common to the area often force us to increase the gain and directivity of the antenna.
The Winegard HD7694P is a good single antenna solution. Start with an aim point of due south. Try this with no amplifier You can add one later if the need is proven.
A premium solution would be an Antennas Direct DB4E and a Antennacraft Y5713 or Y10713. The DB4E would face due south or a bit to the east, to give you the UHF signals available. The YX713 would point at about 190° and would serve up the High-VHF signals (PBS. CW & Fox). Combine the output of the two antennas using a UVSJ.
Start by installing the antenna(s), then before connecting any splitter, check signal quality and tune the aim by connecting only one TV, preferably one with signal metering to aid in aim adjustment. Once the antenna(s) is/are known to produce a reliable signal, add a passive splitter (3-way or 4-way depending on how many sets you'll actually connect). If a signal becomes unreliable you have reason to consider adding a distribution amplifier such as the Channel Master CM-3410. If used, the amplifier is more effective when installed upstream of the splitter, close to the antenna rather than close to a TV.
http://www.amazon.com/Winegard-HD769...ywords=hd7694p
http://www.amazon.com/Antennas-direc...&keywords=db4e
http://www.amazon.com/Antennas-Direc...f+vhf+combiner
http://www.amazon.com/Channel-Master...ywords=CM-3410
Old 26-Feb-2013, 11:21 PM   #6
jd1879
Thank you very much very the prompt detailed info! This is a great start point for me.
Since you are in the seattle area, do you know of or recommend anyone who does this type of install if I buy the equipment?
Old 4-Mar-2013, 12:32 AM   #7
jd1879
I put up the Winegard antenna you suggested. The only station i don't get without breakup is the fox (13.1) station. I have not installed the amplifier since its not here yet. Would this and some antenna direction adjustment likely help this without having to buy a second antenna?
Antenna is about 25 feet up facing 185 degrees.
Thanks.
