Old 24-Feb-2013, 8:34 PM   #1
jjordan414
Need to know what kind of antenna and where to buy
Could someone let me know what type of antenna I could buy locally. It will be mounted on the roof of a commercial building about 25 ft high.
Thank you.
http://www.tvfool.com/?option=com_wr...1dda040d5a2f4f
jjordan414 is offline   Reply With Quote
Old 24-Feb-2013, 9:59 PM   #2
A Simple reception situation that will receive Many Digital Tv Channels and requires a Big antenna.
Install a Winegard HD7698P antenna aimed at about 295 degree magnetic compass direction.
_______________
Install a Antennas Direct CPA-19 preamp.
_______________
_____________________
Here are some Strong and Sturdy antenna mounts.
http://www.ronard.com/909911.html , use the 5 foot tripod antenna mount.
http://www.ronard.com.
______________
As always trees and tree leaves do a good job of , multipath/reflecting , absorbing , blocking , OTA= Over The Air , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and building.
It is best install the HD7698P antenna at a location the has the least amount to no amount of obstructions of any type or kind in the direction of reception including your own roof and building.
The direction of reception at your location is , north west / west.
The Tv's Must Channel Scan for the Digital Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select , 'Air Channels' / 'Antenna Channels.
