Old 22-Feb-2013, 3:43 PM   #1
Bryan
What would be a good antenna for me...
Based on this info, what would antenna would you recommend? Not looking at spending anymore than $130.
http://www.tvfool.com/?option=com_wr...1dda221ddcc0f0
Bryan is offline   Reply With Quote
Old 22-Feb-2013, 5:11 PM   #2
What directions do , windows , patios/balconies , face??
What floor??
What is the top floor??
The tvfool radar report and channel list is not showing any antenna height above ground.
Do not delete the tvfool radar report and channel list and make a second tvfool report and channel list with the Tv antenna height 25 feet above ground.
Old 22-Feb-2013, 9:04 PM   #3
Bryan
I'm sorry, was in a rush... Anyways, its a Raised Ranch, at this time only 2 TV's will be connected and it'll probably have to be an outdoor antenna. It's in the country, so not too close to anything. Here is the other report, http://www.tvfool.com/?option=com_wr...1dda62ce41990e 25 feet above ground.
Old 22-Feb-2013, 10:43 PM   #4
Here is a 1 antenna shot at receiving the Canada Digital Tv stations/channels that are weak signal strength and the Buffalo USA Digital Tv stations/channels that are strong signal strength.
If 1 antenna does not do it then will be required to use 2 antennas to receive both the Canada and USA Digital Tv stations/channels.
For Canada and USA reception with 1 antenna install a Winegard HD7696P antenna aimed at about 305 degree magnetic compass direction for Canada Digital Tv stations/channels.
And the strong USA Digital Tv stations/channels should be received at front angles and back angles to the HD7696P antenna.
As always , the starting aim direction of a antenna is the --> starting aim direction of a antenna.
The aim direction can be adjusted for best reception.
Most Digital Tv's have a signal strength meter and some Digital Tv's also have a signal quality meter.
____________________
Here are some Above the Roof antenna mounts.
http://www.ronard.com/909911.html , if using the tripod antenna mount use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html , if using the eave antenna mount use the #4560.
http://www.ronard.com.
______________
______________
_______________________
As always , trees and tree leaves do a good job of , reflecting/multipath , absorbing , blocking , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best install the HD7696P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
At your location that is , north west , west , south west , south , south east.
_______
The Tv/s Must Channel Scan for the , OTA= Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select , 'Air Channels' / 'Antenna Channels'.
Old 24-Feb-2013, 1:34 PM   #5
Bryan
Thanks for the great info. Do you think I could eliminate the preamp if I use the HD7697 instead? How necessary would the preamp be anyways?
Old 24-Feb-2013, 4:25 PM   #6
I recommended the HD7696P antenna because it is less directive. And as such receives better at front angles and back angles and back of the antenna.
However.
Yes you can try the HD7697P antenna.
____________________________________
I recommended the Winegard HDP-269 preamp because of the Weak signal strengths and distances to the Canada Tv stations.
However.
Yes you can try reception without the preamp.
