Old 22-Feb-2013, 1:32 AM   #1
Td4830
Kabc la
I was wondering if anyone else has had problems recently with receiving KABC? It had been coming in fine for years here at my house in the South Bay. In the last couple of weeks, it's stopped coming in.
Td4830 is offline   Reply With Quote
Old 22-Feb-2013, 7:58 AM   #2
It would be interesting and helpful to see your TV Fool reception report.
Old 24-Feb-2013, 7:49 PM   #3
Td4830
Hi,
I am pasting it below. I have to admit that I'm not very knowledgable about reception. From looking over the report, it seems as thought some of the stations that seem to have similar characteristics come in well, others not at all: 2, 4, 28, 50 are all pretty good, but 9 and 13 don't come in at all.
http://www.tvfool.com/?option=com_wr...1dda7f42006fa6
Thanks very much!
Old 25-Feb-2013, 3:40 AM   #4
Check All outside connections. If water has inter any of the connections , then you can be sure that the water has traveled up into the length of the inside of the coax and the coax is now trash.
Use the Compression type coax connectors outside not the crimp type.
The compression type connectors are a much better seal to prevent water damage.
____________________________
Broadcast Digital Tv tuners can develop - Digital Glitches - that are not cleared out with a simple channel scan.
Do a Double Rescan.
To receive , Many , many , many , many , many , Digital Broadcast Tv stations/channels.
For a above the roof top antenna install a Winegard HD7082P antenna aimed at about 0 degree magnetic compass direction.
http://www.ronard.com/909911.html. Use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Use the #4560 eave antenna mount.
http://www.ronard.com.
Buy the HFS splitters at , http://www.solidsignal.com , http://www.hollandelectronics.com.
As always , trees and tree leaves do a good job of , multipath/reflecting , absorbing , blocking , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7082P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The directions of reception at your location are , north west , north , north east.
______
The Tv's Must Channel Scan for the , OTA= Over The Air , Digital Broadcast Tv stations/channels , often named the , 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select , 'Air Channels' / 'Antenna Channels'.
kabc
