Old 11-Feb-2013, 11:41 PM   #1
whiskeyhill
WRKJ-LD: mystery station
I just rescanned my OTA channels, and am now picking up station WRKJ-LD on virtual channels 22.1 thru 22.6. Of these, 22.3 is the only channel actually broadcasting anything, and that is merely the same PSA running repeatedly. The other channels are blue-screen with a series of moving broken black lines in the upper 1/5 of the screen.
I'm approximately 20 miles WSW of Chicago's lakefront.
I can't find anything regarding this station. Anyone...?
whiskeyhill is offline   Reply With Quote
Old 12-Feb-2013, 3:06 PM   #2
elmo
Have you tried a report for your location? It shows pending stations as well, which may give a clue.
Old 12-Feb-2013, 3:25 PM   #3
Formerly W22AJ, is now WRKJ-LD attempting to operate on UHF 24 as virtual channel 22
See request for STA at https://licensing.fcc.gov/cgi-bin/ws...&fac_num=68061 (read comments in Exhibits section) also http://transition.fcc.gov/fcc-bin/tv...=0&facid=68061
The TVFool database does not reflect the new STA information at this time but shows the granted construction permit although under the old call letters.
Old 12-Feb-2013, 3:33 PM   #4
Typing in the station call sign and variations of the call sign in the google search box , shows that is most likely Religion Tv station.
wrkj , wrkj tv , wrkj-tv , wrkj-ld , and so forth in the google search box , shows some brief and incomplete references to a Tv station.
WRKJ is also a Religion radio station. You can call the radio station and ask about the WRKJ Tv station.
You can also call the other Tv stations around your area , communicate with the engineering departments to find out what is on WRKJ.
_____________________________________
I see that the second link provided by AD Tech is for WRJK. The same Tv station??
Not sure about the first link.
Old 13-Feb-2013, 1:16 AM   #5
whiskeyhill
It looks like they are getting their house in order. I see that this station is an affiliate for AVS TV/Diya TV. All Bollywood, all the time!
