Old 5-Feb-2013, 12:07 AM   #1
ard103
help on choosing antenna
Hello, we are breaking the cable tie and would like a suggestion for an antenna for out location.
our report: http://www.tvfool.com/?option=com_wr...1dda234741d455
Thanks in advance,
alan
ard103 is offline   Reply With Quote
Old 5-Feb-2013, 12:23 AM   #2
If you're not blocked by trees or neighboring buildings, the RCA ANT-751r fits you like a glove. If you're fighting some obstructions, the Winegard HD7694P gives you more gain and directivity to help overcome some of the effects.
Point toward the west, 255° and enjoy lot's of easy to receive signals.
Old 5-Feb-2013, 12:44 AM   #3
ard103
Thanks, we will be fighting some trees.
The antenna will only be about 20 feet high.
Lot'sa lightning around here....
Old 5-Feb-2013, 1:10 AM   #4
Above the Peak of the roof install a Winegard HD7694P antenna aimed at about 265 degree magnetic compass direction.
http://www.ronard.com/909911.html. If using a tripod antenna mount use the 5 foot antenna mount.
http://www.ronard.com/34424560.html. If using a eave antenna mount use the #4560.
http://www.ronard.com.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com.
The Digital Tv transmissions are strong at your location.
No preamplifier is required.
_________________
As always , trees and tree leaves do a good job of , reflecting , reducing , blocking , Digital Tv reception and so do buildings and other obstructions including your own roof and house.
Install the HD7694P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
At your location the 2 main groups of Digital Tv transmitters are to the , south west , west , north west.
The Tv/s Must Channel Scan for the , OTA= Over The Air , Digital Broadcast Tv channels , often named the , 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Digital Tv setup menu and select , 'Air Channels' / 'Antenna Channels'.
If keeping any type or kind of pay cable service such as , cable tv service , cable internet service , cable phone service.
The Tv antenna and the cable delivered service cannot be on the same coax.
As an example , the cable internet service must be on a separate coax.
Yes the coaxes that are in or on the house can be used for the antenna system.
Old 5-Feb-2013, 1:20 AM   #5
Grounding your antenna system is not a difficult or expensive task unless you have a very unusual situation. The basics are outlined in post #20 of this thread: http://forum.tvfool.com/showthread.php?t=901
Old 5-Feb-2013, 1:59 AM   #6
ard103
Thanks to all for the advice, looks like a project for this weekend.
Old 7-Feb-2013, 8:50 AM   #7
ard103
Picked up the RCA ANT-751R at Lowes for $70 mainly because of the small size. Just laying the antenna on the shrubs the televisions tuned in 46 channels! Plenty enough for us. I will get it off the ground and mount it on the workshop eave today, along with grounding the antenna and the coax to the electrical panel ground bar in the workshop.
Thanks again for the advice, saving $50 a month from cutting cable isn't a lot per month, but over the years will add up.
Alan
