Old 2-Feb-2013, 5:43 PM   #1
Jb1984
St Thomas ontario, new to ota. Please help
http://www.tvfool.com/?option=com_wr...1ddaebde38e147
Hey there. First time poster on here and pretty new to getting ota channels. Me and the girlfriend decided to give this a try.
We can get a good few channels here but I'd really like some home help gettin to know if I can get a couple other specific ones, like the CBC and ctv.
We are using just a set top Panasonic antenna on a second floor. Please check out the link for the stats for my area and if you have any tips for how I could get these stations let me know. Thanks.
Jb1984 is offline   Reply With Quote
Old 2-Feb-2013, 10:11 PM   #2
What directions are , windows and patio/balconies??
Old 3-Feb-2013, 7:12 PM   #3
Jb1984
It's a house, on the second floor.
There's one window in the room this antenna will be placed in. It's east facing and about ten feet from where there tv and antenna are placed.
And as well just 1 tv connected in here.
Old 4-Feb-2013, 1:12 AM   #4
For Reception of.
CFPL-DT VHF Digital Channel 10 , CTV TWO.
CJMT-DT UHF Digital Channel 20 , OMNI 2.
CICO-DT UHF Digital Channel 18 , TVO.
CITS-DT UHF Digital Channel 14 , Religion.
CFMT-DT UHF Digital Channel 48 , OMNI 1.
CHCH-DT UHF Digital Channel 51 , IND.
CITY-DT UHF Digital Channel 31 , CITY TV.
CKCO-DT VHF Digital Channel 13 , CTV ONE.
CIII-DT VHF Digital Channel 06 , GTN.
CIII-DT UHF Digital Channel 17 , GTN.
Above the Peak Of The Roof so that reception is not blocked in all directions by the roof or house.
Install a Winegard HD7082P antenna aimed at about 42 degree magnetic compass direction.
______________________________________
(((I found No CBC Digital or Analog Tv stations for , St-Thomas , London , or surrounding area.)))
Also install a Winegard HDP-269 preamp.
Here are places to buy , Antennas , HFS splitters , and etc. , [URL="http://www.saveandreplay.com"]http://www.saveandreplay.com[/URL , http://www.trentondistributors.com] , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.hollandelectronics.com.
_________________________________________
Some Above the Roof antenna mounts are , Tripod antenna mounts , Eave antenna mounts , Chimney antenna mounts.
_____________________________________________
As always , trees and tree leaves do a good job of , reflecting , reducing , blocking , Digital Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7082P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' because the OTA= Over The Air Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Go into the Tv setup menu and select , 'Air Channels' / 'Antenna Channels'.
