Old 30-Jan-2013, 11:17 AM   #1
sofakng
Can I put an antenna in the basement? (3 mile distance from towers)
Here is my TV Fool link: http://www.tvfool.com/?option=com_wr...1dda15919747a1
I'm only 3 miles from my local HDTV towers, so I'm wondering if it would be possible to put an antenna in my basement (which is 80% underground).
If so, does anybody have an antenna suggestion for me? Something small and highly directional I'm guessing?
EDIT: What if I mount a small antenna below the floor joists (in the basement) which is just above ground level (so it's not underground). Might that work?
sofakng is offline   Reply With Quote
Old 30-Jan-2013, 2:29 PM   #2
The --> Only Way <-- to find out.
Is install a Terk HDTVi (not HDTVa) antenna aimed at about 60 degree magnetic compass direction.
Here is how to aim indoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
Old 30-Jan-2013, 4:20 PM   #3
middleofnowhere
it probably won't work. You are only 3 mi from transmitters but the ground will block ALL transmissions. putting it in the joists may work, but with such heavy construction in floors i don't guarentee anything.
Not to mention all sorts of random distortion and diffraction everytime someone walks by upstairs.
Assuming that you only want the big-name transmitters from your 3 mi towers a small directional antenna (upstairs a set-top would be more than enough) sounds like the best bet to me. You can always mount it higher in your house (if possible). You'll need one with UHF/high-VHF capabilities, if you want NBC and CBS.
P.S don't buy too big of an antenna, you're pretty close to your transmitter(s) and you could overload something with a huge antenna.
middleofnowhere is offline   Reply With Quote
Old 30-Jan-2013, 5:10 PM   #4
Over a mile away, overload is very unlikely. At 3 miles, nearly impossible even with a large antenna, unless of course some type of amplification is used.
Old 30-Jan-2013, 7:25 PM   #5
sofakng
I have a Winegard HD7082P at my old house that I still need to move into my new house...
I'm hesitant about putting it up in the attic (because it's a crawl space) but I might just do it and get it over with. However, it does seem like overkill for these local channels, doesn't it?
Should I just buy a Mohu Leaf or something and put that in the attic instead? (I'll still need to drill/run wire into the basement, but what can you do...)
Old 30-Jan-2013, 9:24 PM   #6
If you already own an HD7082P, try it. It's more antenna than I would spec. in this application but it won't break anything. It would certainly provide enough signal power to drive an 8-way splitter if you had the need.
Old 31-Jan-2013, 2:02 AM   #7
Install the HD7082P antenna above the roof , with no preamplifier , aimed at about 40 degree magnetic compass direction , and also receive .
WSWB-DT REAL UHF Digital channel 31 , virtual number (38.1-2) The CW and Me-Tv.
WQPX-DT REAL UHF Digital channel 32 , virtual number (64.1-2-3) ION and Qubo and ION Life.
http://www.ronard.com/909911.html if using a tripod antenna mount use a 5 foot antenna mount.
http://www.ronard.com/34424560.html if using a eave antenna mount use the #4560.
http://www.ronard.com.
Buy the ronard antenna mounts at http://www.solidsignal.com by typing the word ronard in the solidsignal search box or buy from ronard.
