Old 23-Jan-2013, 7:16 PM   #1
DustB
Buying New Antenna - Recommendations
TV Map Report: http://snag.gy/UKi0k.jpg
TV Fool Report: http://www.tvfool.com/?option=com_wr...1ddae461cdf223
Exsisting Antenna: Mono Price MDA-5600
Channels Most Care About:
1. CBUT-DT (CBC): Doesn't show up on TVFool... Maybe it knows something I don't, but, this is one I'd like the most. Various sources say it should be broadcasting in Vancouver BC as ch2.1, aka link
2. The 5 "Greens" (9.1miles away) in the report.
3. Less important, but, CHEK-DT if I can get it.
Existing Problems:
My apartment is ground floor, and on a hill. One side of the apartment (~20feet off ground) has the main living-room window (or covered deck) and is facing the water; south-west. Other side of apartment (north-east) has a single small window but not close to the tv room; this window is also kinda facing a hill (aka have to walk up steep steps to get to road, which is about 25 feet up, shortly after leaving the front door).
With my current antenna I cannot seem to get any channels in the living-room/window/porch (all facing south-west). If I take it across the apt to the small window I can get CHAN-DT. If I take the monoprice antenna outside my front door into the middle of the courtyard (aka where the small window views, and hill/steps start), then I get ~8 channels (down to PBS in report).
I'm looking into buying a new antenna, but unsure what is best for me. Ideally I'd be able to put the antenna in my living room, livining-room window, or porch (which is covered/kinda built into building so maybe not the best location); roof-mount is not an option for me. I was thinking about the following:
1. RCA ANT1650R (living room or window); omni indoor antenna
2. Mohu Leaf (living room window); omni indoor antenna
3. I also notice a lot here reccomend "ClearStream™ 4" or "ClearStream™ 5", would they be best for me?
Or is there a better/stronger choice for me (ideally one that can best handle indoor+building wall environment)? Should I try an outdoor antenna indoors (maybe cut threw walls better?). I read on-line that the "RCA ANT751" (directional) cuts through walls/mountains/etc better than typical antennas, but, would it be able to cut through an entire building if I put it on my porch at the south-west of building (and face it north-east into the building?).
Many thanks.
DustB is offline   Reply With Quote
Old 24-Jan-2013, 7:06 AM   #2
Is your Apartment on the , ~ north , end of the building??
Is your Apartment on the , ~ south , end of the building??
Is your Apartment on the , ~ east , end of the building??
Is your Apartment on the , ~ west , end of the building??
In the middle??
How many floors are above your first floor??
I am fishing for a way to have a antenna situated for better reception to the , north east.
Old 24-Jan-2013, 9:20 AM   #3
DustB
Apartment complex is two building, a north-east building, and a south-west building (courtyard between them). I'm in the south-west building. There are 4 floors above me. But ground level only has 2 apartments for my building (east apt, west apt). I'm in the west apt.
North-east wall of my apartment only has 2 outlets (main door, then a 5 foot tall x 1 foot wide bedroom window). Aiming from the window could be iffy since I'm actually aiming into the other building/hill (but there is a semi open courtyard between the two buildings which does allow for some aiming (mostly up)).
However, I could accommodate larger antennas (~ 6'x6' +) in the living-room than I could in the bedroom (ideally bedroom would be a ~ 2'x1' window type, aka, thinner). Living-room has 11' ceilings so there is lots of head space there, also living-room window is much larger if it helps; again living-room is located south-west, and facing south-west though.
Let me know if there are any other questions.
Old 26-Jan-2013, 7:12 AM   #4
Your current reception location is between a Rock and a Hard Place.
_______________________________________________________
In the Current Plus Pending Applications Included Digital tvfool radar plot report and channel list , CBUT-DT REAL UHF Digital channel 43 , virtual number (2.1) CBC , is listed.
The tvfool report shows the , Real channels , and , (Virt) virtual numbers.
All receivable Digital Tv stations/channels are UHF channels at your current location.
The current UHF Tv channels are , 14 thru 51.
_____________________________________________________________
Try this.
For reception of the Canada Digital Broadcast Tv stations.
Put a Antennas Direct , Clear Stream 2 UHF antenna , in the 5 foot tall by 1 foot wide bedroom window.
Tipping / aiming , the antenna up in the window , might help with reception.
It is experimental aiming to find the best reception.
The Canada Digital Tv transmissions to the , north east , are strong signal strength , so do not use a signal amplifier.
Use a loooong coax to connect the antenna to the Tv.
http://www.antennasdirect.com/store/...V-antenna.html.
Try this.
For reception of the Canada Digital Tv stations channels to the , north east.
If there are any buildings or something to get a reflected Tv signal to the , south west , west.
Put the CS2 UHF antenna in the living room window or out on the patio/porch , and aim the CS2 UHF antenna , toward the buildings if there are any , might be able to get some useable signal reflections , tilting the antenna up might help with reception.
It is experimental aiming to find the best Tv signals.
Use a loooong coax from the antenna to the Tv.
The Canada Digital Tv transmissions to the , north east are strong signal strength so do not use a signal amplifier.
If you find a good , antenna aim/adjusted direction , with simple channel scans.
Then can help to do Double Channel Scan.
Digital Tv tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
______________
Here is how to aim antennas.
Here are some places to buy antennas and etc. ,
http://www.saveandreplay.com.
http://www.solidsignal.com.
http://www.amazon.com.
As a Test of reception for the USA Digital Tv stations/channels.
Try aiming the CS2 UHF antenna the best you can , to a south east / south direction.
A Double channel scan can help with reception.
If some USA Digital Broadcast Tv channels are receivable.
Then I recommend a 2 antenna setup , 1 CS2 antenna for the Canada Digital Tv stations and 2nd. CS2 antenna for the USA Digital Tv stations/channels.
For reception of the USA Digital Tv stations channels a Antennas Direct CPA-19 preamplifier might help with reception.
DO NOT use the CPA-19 preamp for reception of the Canada Digital Tv stations/channels.
If using 2 Separate CS2 antennas , Do Not connect the 2 antennas on to 1 coax.
The 2 Separate antenna systems are Separate all the way to the Tv/s locations.
If 1 Tv is connected use No splitter.
If 2 Tv's are connected use a HFS-2D , 2 way splitter.
If 3 Tv's are connected use a , HFS-3D , 3 way splitter.
Buy the HFS splitters at , http://www.solidsignal.com , http://www.hollandelectronics.com , or , http://www.hollandelectronics.com , http://www.saveandreplay.com . http://www.trentondistributors.com
A remote control A/B antenna switch will be used to change antennas , Canada and USA antennas , and Keep on Channel Surfing.
Saveandreplay has the remote control A/B antenna switch.
Moving to a top floor / 4th floor apartment will help with reception to have reliable reception and most likely more Tv stations and channels.
Select a apartment higher up that has good views to the , north east , south - south east , at a minimum.
And a apartment with good views in all directions will also help with reception.
Old 27-Jan-2013, 4:56 AM   #5
DustB
Thank you, I see CBC now. I'll try that antenna.
