Old 23-Jan-2013, 2:57 AM   #1
blastman
Never had an antenna before but can't take the cable bill anymore
Hello, I like many others it appears have had enough of the 100.00+ a month cable bill, so now it's time for my 1st ever antenna. I put in my address and it gave me this information http://www.tvfool.com/?option=com_wr...1ddaeabf9a3b26 would anyone have any suggestions of a quality antenna that would work good in my area. Thank you very much
blastman is offline   Reply With Quote
Old 23-Jan-2013, 3:36 AM   #2
The tvfool radar plot report says , with red letters , that the tvfool radar plot report is resolved to the city level only.
Please make a tvfool radar plot report with the Exact address. With the antenna height at 20 feet.
If the Exact address will not work.
On the tvfool home page click on >>Start MAPS<< , make a map , Move the Pointer to your Exact location , and click on the button , Make Tvfool Radar Plot.
What directions do , windows , patios/balconies face??
What floor??
What is the top floor??
Old 23-Jan-2013, 3:20 PM   #3
Dinesh
Good news is that you have so many channels in green, bad news is that channels which most of the folks are interested NBC, ABC, CBS & FOX do not have line of sight. You need one antenna pointed 1 degrees magnetic (NBC, PBS, ABC) and one antenna pointed 103 degrees (CBS & FOX). Two antennas of clearstream C2V should work.
You may want to wait for experts opinion if you can get one antenna which can get from front and back.
Dinesh.
Dinesh is offline   Reply With Quote
Old 23-Jan-2013, 4:56 PM   #4
blastman
Thank you so much for your information, it is greatly appreciated.
Old 26-Jan-2013, 1:57 PM   #5
No respond.
Well any way.
Based on the tvfool report at the city level.
Install a Winegard HD7000R antenna above the Peak of the roof aimed at about 90 degree magnetic compass direction.
Buy the HFS splitters at , http://www.solidsignal.com or http://www.hollandelectronics.com.
______________________________
For the reception of.
K20DT REAL UHF Digital channel 38 , virtual number (20.1) has CP construction permit.
K15BP-D REAL UHF Digital channel 15 is a repeater station of , KDRV-DT REAL VHF Digital channel (12.1) ABC.
K44JB-D REAL UHF Digital channel 44 is a repeater station of , KMUV-DT FOX and Me-Tv.
K49JE-D REAL UHF Digital channel 49 is repeater station of , KOBI channel 5 NBC and Weather.
KBLN-DT REAL UHF Digital channel 30 , virtual number (30.1) Religion.
K04EY REAL VHF Digital channel 04 , has a CP construction permit to be a repeater of KOBI NBC.
K19HS-D REAL UHF Digital channel 19 is a repeater station of , KSYS-DT channel 08 PBS.
K22FC REAL UHF Digital channel 22 , virtual number (22.1) Religion.
K47GI REAL UHF Digital channel 47 , virtual number (47.1) Religion.
K02JJ-D REAL VHF Digital channel 02 is a repeater station of , KSYS-DT channel 08 PBS.
K04JZ REAL VHF Digital channel 04 is a repeater station of , KTVL VHF channel 10 CBS and CW.
http://www.ronard.com/909911.html if using the tripod antenna mount use the 5 foot mount.
http://www.ronard.com/34424560.html if using the eave antenna mount use the #4560.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal buy typing the word ronard in the solidsignal search box or buy from ronard.
_______
Can also use a Winegard DS3000 , J type antenna mount.
_______
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com.
_______________
As always , trees and tree leaves do a real good job of , reflecting , reducing , blocking , Digital Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7000R antenna at a location that has the least amount to no amount of obstructions of reception including your own roof and house.
The directions of reception are , north east , east , south east.
