Old 4-Jan-2013, 6:04 PM   #1
cjschook
Help with Antenna, tuner, etc
Hello all,
I am very new to OTA technology, so I am hoping to get some help. Below is my report from TV Fool. Can someone please recommend an antenna/tuner/etc for me? I would like to install a mast style on my roof. I was looking at antennasdirect, but I do not know if I would need some that rotates... stationary, etc.
http://www.tvfool.com/?option=com_wr...c84f2c3078cb2e
Thank you all in advance!
Chris S
cjschook is offline   Reply With Quote
Old 4-Jan-2013, 7:11 PM   #2
Your TV Fool report appears to be based on a default antenna height of 10' above ground. Looking at the path profile of WABC, it looks as if roof mounting (20' to 30' AGL) could improve your report and alter the antenna recommendation(s) significantly. Please generate and post a TVFR using 25' AGL. (I suspect you have a very nice shot toward NYC).
Old 4-Jan-2013, 7:18 PM   #3
cjschook
25ft AGL
Here is my updated with 25ft AGL THANK YOU!
http://www.tvfool.com/?option=com_wr...c84f7fa3dcb1a1
Old 4-Jan-2013, 7:50 PM   #4
Conditions certainly get better as you increase the antenna mounting height. Feel free to experiment with high AGL values if you think you can mount higher than 25'.
If 25' AGL is the highest practical mounting for you, consider a Winegard HD7698P or HD7084P pointed toward NYC. You can expect the strong signals from the opposite direction to be received also. If you are going to drive a splitter, you'll want to also install an Antennas Direct CPA-19 preamp close to the antenna. If you can't find a CPA-19, the Winegard HDP-269 would be another option.
Old 4-Jan-2013, 9:43 PM   #5
Many , many , many , many , many , many , Digital Tv stations/channels will be received.
Install a Winegard HD7084P antenna aimed at about 272 degree magnetic compass direction.
Here are some strong and sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
___________
For 1 Tv connected use no splitter and no preamplifier.
For 2 or more Tv's connected use a Antennas Direct CPA-19 preamp.
__________
Trees and tree leaves do a real fine job of reducing or blocking Digital Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7084P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
At your location the directions of reception are , west , north , north east , east.
__________
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Some Tv's will automatic channel scan for cable tv channels.
In the Tv menu select the 'Air Channels'/'Antenna Channels' to scan for channels.
DO NOT Channel Scan For Cable Tv Channels.
Old 13-Jan-2013, 11:42 PM   #6
cjschook
Thanks for the help! I installed the antenna and preamp today. I am able to get some channels, but not able to get FOX or NBC. I guess I have to do some tweaking and more research....
Old 14-Jan-2013, 3:51 AM   #7
------>To Prove Reception.<------
Connect the simplest way.
Connect a Looooong coax to the HD7084P antenna and run the Looooong coax through a open door or window direct to one Digital Tv.
No ground blocks , No splitters , No couplers , No nothing.
If you have the CPA-19 preamp , try reception without and with the CPA-19 connected.
Digital Tuners can develop Digital Glitches that are not cleared out with a simple channel scan.
Do a Double Channel Scan.
Aim the HD7084P antenna at about 272 degree magnetic compass direction.
As always , the starting aim direction of the antenna is the --> starting aim direction.
The aim direction can be changed to find the aim direction with the best reception.
_____________________________________________
As always , trees and tree leaves do a good job of , reflecting , reducing , blocking , Digital Tv reception and so do buildings and other obstructions including you own roof and house.
The Tv Must Channel Scan for the Digital Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Some Digital Tv's , automatic channel scan for cable tv channels.
Go into the Tv setup menu and Select , 'Air Channels'/'Antenna Channels'.
