Old 5-Dec-2012, 11:26 PM   #1
Texas Kid
Red face Antenna Advice
I live in College Station, Tx and direct TV just raised my rate $30.00 month. The only other option is streaming video and replacing the Direct Tv dish on the roof with an Antenna. I need so advise on the best Antenna to purchase. Listed below is my info.
Thanks for your help
http://www.tvfool.com/?option=com_wr...q=id%3dcc49ca2
Texas Kid is offline   Reply With Quote
Old 6-Dec-2012, 12:44 AM   #2
elmo
Hey TK - Redo your plot - the link you posted isn't loading up.
Old 6-Dec-2012, 1:02 AM   #3
Texas Kid
Sorry about that. Try this one
http://www.tvfool.com/?option=com_wr...cc49955c56729b
Old 6-Dec-2012, 5:32 AM   #4
Based on the tvfool radar plot report and channel list that is resolved to street level and not the Exact address.
Install above the roof in such a manner that the roof and house is not blocking reception to the , north west and east , install a Winegard HD7696P antenna aimed at about 310 degrees magnetic compass direction.
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , if installing a eave antenna mount use the #4560 , http://www.ronard.com/ychim.html , http://www.ronard.com.
No preamp is required.
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install the HD7696P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Old 27-Mar-2014, 8:16 PM   #5
Texas Kid
Preamp question
I have a Winegard HD7696P antenna with a cheap 4-way 10dB UHF/VHF FM Amplifier that I purchased at Lowes. It help boost the signal enough on two of the ten channels. Lately one the channels come and goes through out the day with loss of signal.
Is there a Amplifier you could recommend that might boost the signal enough. Some days there is not an issue, other days it's up and down.
Old 27-Mar-2014, 8:47 PM   #6
The RCA TVPRAMP1R is a remarkably good preamplifier. It's tolerant of strong signals and seems to generate no more noise internally than more expensive amplifiers from the competition... And the price is very competitive.
Old 28-Mar-2014, 1:45 AM   #7
Weather/Water gets into outside connections and coax and carrodes the connections and degrades reception.
For outside coax use coax that has the Compession type connectors on the ends of the coax. Not the crimp type connectors.
To make double sure that weather/water does not get into clean and correct connections wrap with , www.coaxseal.com
Last edited by teleview; 28-Mar-2014 at 4:56 PM. Reason: Clarify information and typos.
