Old 4-Dec-2012, 9:21 PM   #1
musicman
getting started
HI:
I am renovating my parent's cottage and would like to see what TV reception I can get using OTA equipment.
Here is my location http://www.tvfool.com/?option=com_wr...cc49bec0740911
I am completely new to this and am looking for help relating to:
what antenna I should buy,
what channels I might get,
is the make of the TV important.
I have an old TV tower, which is about 20 feet off the ground, and has an old antenna on it.
The wire attached to it is the kind which is brown in colour and has 2 wires embedded on each edge in the brown plastic.
I could attach a new antenna to the old tower if that would help.
The cottage is only used from May to October.
Thank you in advance for any help that you might be able to give.
Thanks,
musicman39@gmail.com
musicman is offline   Reply With Quote
Old 4-Dec-2012, 10:33 PM   #2
For reception of ,
CFTO-TV Analog Channel 21 CTV ONE.
CIII-DT Digital channel 7 GTN Global.
CHCH-DT Digital channel 23 IND.
CKVR-DT Digital channel 10 CTV TWO.
Install on the tower , a Winegard HD7696P antenna aimed at about 220 degree magnetic compass direction.
No preamplifier is required.
For 1 Tv connection use no splitter.
___________________________________________
Here are places to buy antennas and etc. , http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.amazon.ca , http://www.solidsignal.com , http://www.winegarddirect.com.
The Tv should be a Tv that receives both the Digital Broadcast Tv Channels and Analog Broadcast Tv Channels.
Replace All of the Antenna and inside wiring with New RG-6 coax wiring.
__________
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
At your location that is , west and south.
Old 6-Dec-2012, 11:56 PM   #3
musicman
HI TELEVIEW:
Thank you so much for your quick response.
You have answered all my questions perfectly.
I just had one other question.
If I go to a store like Future shop or Best buy, etc, will they be able to tell me if the TV's they have for sale receive both the Digital Broadcast Tv channels and the Analog Broadcast Tv Channels?
Thanks once again for your help.
Regards,
Musicman
Old 7-Dec-2012, 3:20 PM   #4
Clause
As I understand it, the TV will require an ATSC Tuner (http://en.wikipedia.org/wiki/ATSC_tuner in order to pick up over the air digital and analog signals. When you find a TV you like, check the details tab on the Future Shop (or BB) site and scroll down to the TV Tuner section. You'll find something similar to TV Tuner ATSC; NTSC; QAM. NTSC is the North American 60Hz signal standard, ATSC allows for digital OTA reception, and QAM allows for the reception of unencrypted digital cable signals without a cable box.
Clause is offline   Reply With Quote
Old 7-Dec-2012, 4:13 PM   #5
All new Tv's will receive both Digital Broadcast Tv Transmissions and Analog Broadcast Tv Transmissions.
Old 7-Dec-2012, 5:41 PM   #6
musicman
Thanks!!
HI Clause:
Thanks for your quick response.
Now I know exactly what to do to get the best reception.
This TV FOOL website is a godsend.
Thanks,
Musicman
