Old 1-Dec-2012, 3:17 AM   #1
DellboyAA
Smile Need assistance with equipment and antenna
Hi.
I am going to purchase an antenna and would appreciate any assistance in determining which one and what additional equipment I would need to maximize my reception. Here is the TV Signal Analysis Results
http://www.tvfool.com/?option=com_wr...cc491f0707d8b7
Thank you for your help.
DellboyAA is offline   Reply With Quote
Old 1-Dec-2012, 3:49 AM   #2
Is this a , house , town home , apartment , condo , mobile home , motor home , or etc.??
What directions do the windows face??
What floor??
What is the top floor??
What directions do , patios , balconies , face??
Old 1-Dec-2012, 5:34 AM   #3
DellboyAA
Hi
Thanks for replying. This is a single story 3 bedroom house.
There are windows facing every direction, no patios or balcony's
3 TV's will be connected.
I can easily mount an antenna on the roof
Thank you.
Old 1-Dec-2012, 6:23 PM   #4
Above the roof install a Winegard HD7082P antenna aimed at about 230 degree magnetic compass direction.
It is best to install the antenna in such a manner that roof or house is not blocking reception in the directions of reception , south west , west , north west , north east , south east.
No preamplifier is required.
For 3 or 4 Tv's connected use a Channel Master CM3414 distribution amplifier.
____________
Here are some strong and sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.channelmasterstore.com.
_______
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install the HD7082P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
The reception directions are , south west , west , north west , north east , south east.
