Old 18-Nov-2012, 2:31 PM   #1
travis7
antenna suggestions
Thank you in advance for any help or suggestions anyone can provide.
I recently purchased a cabin with an existing antenna mounted approx. 30 ft. above the ground. I am not sure what kind of antenna it is. The only way to get any reception is to have a booster in line and then the only channel I can get consistently is CBS. I will sometimes get ABC and PBS. I would like to be able to get FOX and NBC if possible. There is some tree coverage inline in all directions. I will only have 1 TV hooked up with no splitters. Any suggestions for the best type of antenna and/or manufactures would be greatly appreciated.
Thank you
Travis
http://www.tvfool.com/?option=com_wr...cc494f37435a63
travis7 is offline   Reply With Quote
Old 18-Nov-2012, 4:00 PM   #2
The Tv reception is Very Weak at your location.
To see how much signal strengths improve please make 3 more tvfool radar reports with antenna heights of , 60 , 80 , 100 , feet .
Old 20-Nov-2012, 2:34 AM   #4
For reception of , at 30 feet antenna height.
Antenna System number 1.
KAWB REAL Digital UHF channel 28 , virtual number (22.1-2-3-4-5) PBS HD and PBS SD and PBS Kids and PBS Create and Minnesota Channel.
KCCW REAL Digital VHF channel 12 , virtual number (12.1) CBS.
Install a Winegard HD7698P antenna aimed at about 280 degree magnetic compass direction.
Install a KitzTech KT-200 remote power amplifier booster with the HD7698P antenna.
_________________________________________________________________
For reception of , at 60 feet antenna height.
Antenna System number 2.
WDSE-DT REAL Digital VHF channel 8 , virtual number (8.1-2-3-4) PBS and PBS Satellite Service and PBS Create and Minnesota Channel.
WDIO-DT REAL Digital VHF Channel 10 , virtual number (10.1) ABC.
KQDS-DT REAL Digital UHF channel 17 , virtual number (21.1) FOX.
KBJR-DT REAL Digital UHF channel 19 , virtual number (6.1-2) NBC and MyNetwork.
Install a second HD7698P antenna with a KT-200 booster aimed at about 72 degree magnetic compass direction.
Antenna systems numbers 1 and 2 are not connected together on to one coax.
Antenna systems 1 and 2 are Separate antenna systems all the way to the location/s of the Tv/s.
At the location/s of the Tv/s will be a Remote control A/B coax antenna switch at each location.
A/B antenna switching is Channel Surfing Friendly , press the button on the hand held remote control , change antennas and Keep On Channel Surfing.
Using a rotor with one antenna is not channel surfing friendly , must wait for antenna to rotate and not every one in the house will agree with the direction the antenna is aimed.
For antenna system number 1.
For 2 Tv's connected use a , HFS-2D , 2way splitter.
For antenna system number 2 it's the same but separate set up.
But the HFS splitters at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
It is best to install antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv/s Must Channel Scan for Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
