The CS2 antenna is a UHF channels 14 thru 51 antenna.
Your location also has VHF high band channels 7 thru 13.
Install the VHF antenna kit on to the CS2.
http://www.antennasdirect.com , has the VHF antenna kit.
Aim the CS2 with the VHF antenna kit installed.
At about 330 degree magnetic compass direction.
Here is how to aim antennas ,
http://www.kyes,com/antenna/pointing/pointing.html.
The Digital Broadcast Tv stations/channels , are Strong Signal Strength at your location.
Here is a list of the receivable Digital Broadcast Tv stations/channels at your location.
KTWU REAL VHF channel 11 , virtual number (11.1-2-3) PBS.
KSNT REAL UHF channel 27 , virtual number (27.1-2) NBC and FOX.
http://en.wikipedia.org/wiki/KSNT
KSQA REAL VHF channel 12 , virtual number (22.1) The Country Network.
KTMJ-CD REAL UHF channel 43 , virtual number (43.1) FOX.
http://en.wikipedia.org/wiki/KTMJ-CD
K40IJ-D REAL UHF channel 40 , virtual number (x) EICB Religion.
WIBW-TV REAL VHF channel 13 , virtual number (13.1-2-3) CBS and MyNetwork and Me-Tv.
KTKA-DT REAL UHF channel 49 , virtual number (49.1-2) ABC and The CW.
WIBW-TV REAL UHF channel 44 , virtual number (13.1-2-3) CBS and MyNetwork and Me-Tv.
___________________________________
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best install the antenna at a location that has little obstructions to no obstructions of any type or kind in the directions of reception including your own house.
At your location that is , west , north west , north east.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
__________________________________________
Remove All Dish Network connection hardware such as , diplexers , splitters , power supplies , power injectors , and etc..
Have only 1 Tv location connection to the antenna , do not use any splitters.
Now Rescan for Digital Broadcast Tv Channels.
Digital tuners can develop 'digital glitches' that are not cleared out with a simple channel rescan.
Do a Double Rescan.
What is reception like Now??
---> Important Question <---> how many Tv's are connected??
