Old 5-Nov-2012, 2:30 PM   #1
a1tima
Advice requested for antenna choice.
Hello,
I would like to go OTA but as a newie needs advice on chosing antenna and gear for my location. Link to report:http://www.tvfool.com/?option=com_wr...cc49cfded8c2c0
I want to receive the local stations at 282deg. and 101 deg. and maybe cbs 22 at 183 deg. but that would be a bonus. thank you for your help.
a1tima is offline   Reply With Quote
Old 5-Nov-2012, 3:34 PM   #2
For reception of the Canada Digital Tv stations/channels to the , north west , down to and including CJNT-DT UHF channel 49 City Tv / Omni Tv. http://en.wikipedia.org/wiki/CJNT-DT.
And WCFE-DT 38 PBS to the , south west. http://www.en.wikipedia.org/wiki/WCFE-DT.
Above the roof install a Winegard HD7698P antenna with a Antennas Direct CPA-19 preamp , aimed at about 280 degree magnetic compass direction.
Some common above the roof type antenna mounts are , tripod mounts , eave mounts , chimney mount.
Buy the HFS splitters at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
Here are some places to buy antennas and etc. , http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.canadapost.ca/shopper.
It is best to mount the HD7698P antenna at a location that has the least amount to no amount of obstructions in the directions of reception.
The other USA Digital Tv stations are not receivable at the 20 foot antenna height.
To see how low or high will have to be for reception.
At tvfool in the the box that says enter antenna height , put in lower and higher antenna heights then 20 feet to get the some of the other USA Tv stations in to the Red reception zone or better yet into the Yellow reception zone.
Old 6-Nov-2012, 5:25 AM   #3
a1tima
