Old 3-Nov-2012, 12:54 PM   #1
metromack
Back up system
Hello I would like get a back up system for my current setup. I plan on installing
my antenna on a detached garage approximately 75 feet from where my tv is. After reading some posts this would give me the best obstruction free view towards the nyc area any help and or comments would be appreciated. thanks
metromack is offline   Reply With Quote
Old 3-Nov-2012, 2:54 PM   #2
Please do as the other question do and do this -> http://forum.tvfool.com/showthread.php?t=4.
Please make a tvfool radar plot report.
Use your Exact address to make the tvfool radar plot report.
Make the antenna height 25 feet.
Old 4-Nov-2012, 12:50 PM   #3
metromack
Sorry here is the info only planning on one tv thanks
http://www.tvfool.com/?option=com_wr...cc497eac162525
Old 4-Nov-2012, 9:14 PM   #4
I reverse engineered your location to close to your location.
The Tv reception is Very Weak of signal strength for the NYC transmitters.
And as I suspected , due to terrain hills between your location and the transmitters at NYC , a lower antenna height then 25 feet is better for reception.
This often happens over distance and hills.
The signals are weak at distance and tend to bend downward as the signals cross the hilly terrain.
So lower antenna height of 10 feet or so is better for reception.
The NYC Tv transmissions are Weak signal strength.
Install a Winegard HD7084P antenna with a Kitz Tech KT-200 remote power amplifier booster.
The KT-200 remote power amplifier booster provides the flexibility to install the booster unit outside or inside.
Aim the HD7084P antenna at about , 225 degree magnetic compass direction.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.kitztech.com.
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv Must Channel Scan for the Digital Broadcas Tv Channels , sometimes nimed the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna the the receiving antenna.
DO NOT channels scan for cable tv channels.
Old 5-Nov-2012, 12:41 PM   #5
metromack
Thanks for the info. I find it interesting that a lower height would work out
better. Kind of goes against everything I thought and was taught but that's
why I ask questions to those of you who know.
