Old 24-Oct-2012, 6:09 PM   #1
josephbrown
high winds and spaghetti
http://www.tvfool.com/?option=com_wr...2df9799bab454f
I am looking for a new antenna
we get pretty bad stroms with high winds in the ft. campbell area
my channmaster 2018 turned to spaghetti on the mast in our last storm.
and a winegard 7015 before that
I also have trounble with channels 8 and 36
I was thinking about AntennaCraft HD850 or a 290
what do you think can you suggest something
i known i do not need low vhf and I hate the 4228hd
i have a friend that had one and it wound up in the trash
I am tired of the cheep junk they make now
my grandfather had a combo radio shack vhf/ufh for years in central michigan
which one will hold up
i dont care about the price
thank guys for the forum
josephbrown is offline   Reply With Quote
Old 24-Oct-2012, 7:13 PM   #2
signals unlimited
To keep the wind load down, I would use a two bay antenna with a single dipole High VHF element connected thru an amplifier with seperate UHF/VHF inputs.
The Antennas Direct CS2 Complete with a Winegard AP 2870 amplifier would work quite well.
A much stronger antenna with the same reception charactetistics would be the all fiberglass Triple Play antenna with the VHF add on. available at www.tripleplayantenna.com.
Old 24-Oct-2012, 9:31 PM   #3
The Antennas Direct , ClearStream 2 Complete UHF/VHF antenna , http://www.antennasdirect.com/store/...VHF-Combo.html , Has a -->Built In Combiner<-- that combines the UHF and VHF parts of the antenna to 1 coax output of the antenna.
There is No Requirement for a preamplifier that has separate inputs for UHF and VHF. There is NO requirement for a AP2870 preamp that has separate inputs.
_____________________________________
I recommend a , -> Heavy Duty <- Winegard HD7696P aimed at about 145 degree magnetic compass direction.
Here is how to aim antennas , http://www.kyes.com/antennas/pointing/pointing.html.
The HD7696P antenna will receive All of the , Digital Current Plus Pending Applications Included Broadcast Tv stations/channels in the the , Green and Yellow reception zones of the tvfool channel list.
For 1 Tv connected use no splitter. No antenna amplifier.
For 2 Tv's connected use a common simple 2 way splitter. No antenna amplifier.
For 3 Tv's connected use a common simple 3 way splitter. No antenna amplifier.
Here are some Strong and Sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard/ychim.html.
If you choose to install one of the Strong and Sturdy ronard antenna mounts , buy them at solidsignal by typing the word ronard in the solidsignal search box.
Here are some but not the only places to buy antenna and ect. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com.
As always trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install the antenna in a manner that has the least amount to no amount of obstructions of any type or kind in the direction of reception.
Old 25-Oct-2012, 8:22 AM   #4
If you were asking, 'to get all possible signals', I would favor the much larger Winegard.
But given your experience with wind damage, the compact antennas (CS2 w/VHF or the Triple Play) are the direction I would go.
