Old 20-Oct-2012, 5:31 AM   #1
thom
VHF dipole cross
Wondering if a VHF dipole cross is a viable design. To explain, a dipole has a front/back reception pattern with nulls at +/- 90 degrees from boresight. If you had two dipoles, one oriented 90 degrees offset from the other, would you have a viable omnidirectional VHF antenna, assuming the stations were distant enough to not overrun the edges of the nulls?
thom is offline   Reply With Quote
