Old 19-Oct-2012, 2:25 AM   #1
8691stang
Please suggest an antenna, North Carolina
Hi all
About a year ago i bought a indoor antenna which gets spotty reception. I am looking for a reccomendation on what antenna to use as this is my primary device. I also have netflix. I am looking to get as many channels as possible. Any assistance is greatly appreciated.
Thank You
8691stang is offline   Reply With Quote
Old 19-Oct-2012, 2:30 AM   #2
Please post a link to your TV Fool report. Thanks
Old 19-Oct-2012, 2:32 AM   #3
8691stang
Sorry i completely forgot to link it
http://www.tvfool.com/?option=com_wr...2df905bdde3c36
Old 19-Oct-2012, 3:51 AM   #4
A Simple reception situation.
Above The Roof install a ANT751 antenna with , no preamplifier , aimed at about 230 degree magnetic compass direction.
http://www.solidsignal.com , has a ANT751 antenna with a J type antenna mount , low dollars.
For 2 tv's connected use a common simple 2 way splitter.
It is best to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
At your location that is , north , west , south west , north east.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Old 20-Oct-2012, 2:18 AM   #5
8691stang
What if I want to hook up more than 3 tvs?
Old 20-Oct-2012, 2:35 AM   #6
First, verify that you have a reliable signal at the antenna. This is done by connecting only one TV, with no splitter. Once this is done, add the splitter (with the number of ports needed) and recheck the signal quality at each TV. If you have reliable reception, you're done. If the addition of a splitter causes some signals to become unreliable, add a Channel Master CM-3410 distribution amplifier ahead of the splitter.
