Old 6-Oct-2012, 12:00 AM   #1
terrybaz
Low mountain?
My analysis shows that I should easily be able to pick up the local channels. The problem is that there is a low mountain between me and the towers. So, distance isn't a problem and even though I live in a major city, Phoenix, wouldn't the mountains block some of the signals? I am in a sort of valley and until recently had problems with cell reception. Should I look for a satellite dish?
terrybaz is offline   Reply With Quote
Old 6-Oct-2012, 1:39 AM   #2
Please help us help you. By posting a link to your TV Fool Reception report, you'll give us enough information to answer your questions.
Old 6-Oct-2012, 1:55 AM   #3
terrybaz
Oops!
Here is the analysis:
http://www.tvfool.com/?option=com_wr...2df9d7825c3631
Old 6-Oct-2012, 3:51 AM   #4
Many Digital Tv stations/channels will be received.
Above The Roof install a Winegard HD7698P antenna and a Antennas Direct CPA-19 preamp , aimed at about 174 degree magnetic compass direction.
For 3 Tv,s connected use a , HFS-3D , 3 way splitter.
For 4 Tv's connected use a , HFS-4D , 4 way splitter.
Buy the HFS splitters at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
Here are some Strong and Sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
It is best install the HD7698P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the direction of reception.
The Tv/s Must Channel Scan for the Broadcast Tv Channel , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
