Old 17-Sep-2012, 8:41 PM   #1
Go4broke45
Another first timer..need someone to analyze results
Help,
Ok, the girl friend and are a fed up with Charter's price increases and we are attempting to ditch the cable and go DTW free. We would obviously like to get the most channels as possible. We have a two story house and I will be installing a tri pod roof antenna. Here is the analysis of tvfools
http://www.tvfool.com/?option=com_wr...5ed69754fee6e4
Here is also a link from another site
http://www.palgear.com/location/MI/s...h+Street&add2=
Can someone recommend an antenna (s), power amp that would be needed. Fringe stations are not that big of deal.
Thank you
Go4broke45 is offline   Reply With Quote
Old 17-Sep-2012, 11:22 PM   #2
The following is a Teleview recommendation for Digital Broadcast Tv Reception.
A Simple reception situation for reception of the group of broadcast Tv stations/channels to the south , 180 degree magnetic compass direction.
Above the roof install a Winegard HD7698P antenna with no preamplifier aimed at about 180 degree magnetic compass direction.
For 3 or 4 Tv's connected use a Channel Master CM3414 distribution amplifier.
Here are someplaces to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.channelmasterstore.com.
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the direction of reception.
