Old 15-Sep-2012, 3:46 PM   #1
kbuns99
Antenna Recommendation - Virginia
http://www.tvfool.com/?option=com_wr...5ed690e906fa83
I am replacing antennas that are original to our house (~20 years old). They are in bad shape, but I still get decent reception. I figured that if I upgrade, it can only get better.
We live exactly halfway between Richmond, VA and Charlottesville, VA (~30-35 miles to each). I get most channels right now, but signal is somewhat weak on some depending on day, weather, etc.
I would like to get all stations I currently get (which are most stations in red and yellow). I don't get 65.1 on a regular basis and I don't get 27 or 16 at all. I would like to get them, if possible.
I would like to get signal to 2 TV's right now and possibly to a 3rd TV in the future. I would like to put the antenna in the attic if possible. I have tall trees close to sides of house but in front and back of house trees are 100 yards away and we live on a hill so the house is elevated a bit.
Please let me know if you need anymore info. Thanks for your help!
kbuns99 is offline   Reply With Quote
Old 15-Sep-2012, 5:12 PM   #2
The following is a Teleview recommendation for broadcast Tv reception.
A Simple reception situation.
The antenna Will Not be in the attic.
Above The Roof , install a Clear Stream 2 Complete UHF/VHF antenna aimed at about 315 degree magnetic compass direction.
Remove the - reflector screen - from the CS2 Complete so the antenna will receive both directions , Richmond and Charlottesville Digital Tv stations/channels.
For 1 Tv connected use no splitter , use no amplifier.
For 2 Tv's connected use a , Channel Master CM 3412 distribution amplifier.
For 3 or 4 Tv's connected use a CM 3414 distribution amplifier.
Here are some above the roof antenna mounts , http://www.ronard.com/9809911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.channelmasterstore.com.
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including you own house.
It is best to install the CS2 Complete at a location that has the least amount to no amount of obstructions of any type or kind of obstructions in the directions of reception to the north west and south east.
Old 15-Sep-2012, 5:20 PM   #3
The following is a Teleview recommendation for broadcast tv reception.
I am not there to see the house and surrounding area , the sides of the house are what directions??
The front and back of the house are what directions??
Old 15-Sep-2012, 7:22 PM   #4
kbuns99
Back of the house faces east (to Richmond) and front of the house faces west (to Charlottesville).
Why does the attic not work?
Old 15-Sep-2012, 9:37 PM   #5
Some Tv transmissions at your location are weak signal strength.
As always , attics at best will reduce signal strength.
Start with the antenna in the attic , if ,
WVAW ABC.
WAHU FOX and MyTvNetwork and This Tv.
WRID Daystar.
WVPY PBS.
Are not received then move the antenna to above the roof.
Old 16-Sep-2012, 2:18 AM   #6
kbuns99
Is it hard to remove the reflector screen? Is it held on by clips or something like that?
Old 16-Sep-2012, 3:20 AM   #7
The reflector screen is held on with metal clips , easy to remove.
Are you searching for a way to not get Tv reception??
