Old 14-Sep-2012, 2:42 PM   #1
frank-datank
Indianapolis - 5mi distance, channel trouble
Hello,
I'm having issues with just one channel, FOX 59 here in Indianapolis, IN. Here's a link to my location report: http://www.tvfool.com/?option=com_wr...5ed6d21a2074f9
I'm currently using an attic-mounted Winegard MS 2000 Omni-directional antenna, which is being split into 3 signals throughout the house. One is being fed through a TiVo premier, which is where I'm getting the signal strength numbers.
All of my local channels are roughly 5 miles away in a similar direction. And since this is Indiana, the biggest hills we have are speed bumps.
All channels come in great and are consistent, but I can't seem to get 59 in without interruptions. The signal strength averages 35-50, then will drop to 0 periodically. Sometimes once or twice an hour, sometimes once a minute.
I just got an RCA ANT751R hoping the directional would help, but it gives me the same issue.
Any help would be MUCH appreciated.
frank-datank is offline   Reply With Quote
Old 14-Sep-2012, 4:13 PM   #2
The following is a Teleview recommendation for broadcast Tv reception.
As always , attics are Not the best location for digital broadcast Tv reception.
Install the omnidirectional antenna above the roof in such a manner that there are little to no obstructions to reception in all directions.
Install the ANT751 antenna Above The Roof in such a manner that there are little to no obstructions to reception in all directions.
Aim the ANT751 antenna at about 327 degree magnetic compass direction.
As always , trees and trees leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions.
It is best install a antenna at a location that has the least amount to no amount of of any type or kind of obstructions to reception.
Old 15-Sep-2012, 5:45 AM   #3
Most likely the problem is multipath , reflected Tv transmissions bouncing around in the attic.
Get the antenna out and up in the clear.
