Old 17-Jan-2011, 4:25 PM   #1
Kryptonboy
Burbank Help
I picked up a GE outdoor futura omni-directional antenna and hoisted it up the mast on my roof, but only get about 12 channels: 9, 11, 13 and higher. Do I need a rooftop directional antenna to get NBC, ABC, CBS or is a better grade omni-directional acceptible and if so can someone recommend a reliable brand/model in either case? I'm a little overwhelmed by the amount of info on zones and antenna types. Thanks so much!
Kryptonboy is offline   Reply With Quote
Old 17-Jan-2011, 5:32 PM   #2
Please post a signal analysis report to help us help you...
Old 17-Jan-2011, 5:37 PM   #3
Kryptonboy
Signal Analysis
http://www.tvfool.com/?option=com_wr...3cf4b8436fba07
Here's the link to my signal analysis. Thanks!!
Old 17-Jan-2011, 6:40 PM   #4
It looks like the Verdugo mountain range is obstructing your view of Mt Wilson. You are in a fairly deep shadow so to speak. I would not look to an omnidirectional antenna in your situation. You need an antenna capable of gathering a weak signal, for example:
http://www.solidsignal.com/pview.asp...0Antennas&sku=
Many antennas with built in amplifiers are prone to signal overload. In a metropolitan area like Burbank there are likely many sources or RF interference that could pose a problem to an amplifier designed for low signal levels. You will need an amplifier though, so I would suggest one capable of high input levels. For example:
http://www.solidsignal.com/pview.asp...u=615798396145
Aim at about 65° according to your compass. The antenna will perform much better if located outside, clear of obstructions. Generally, the higher you mount the antenna, the better. But in your case, even a 100' tower will not give you a clear line of site. Therefor, be prepared to experiment with the exact mounting height and aim point.
Old 17-Jan-2011, 9:03 PM   #5
Originally Posted by Kryptonboy View Post
Do I need a rooftop directional antenna to get NBC, ABC, CBS or is a better grade omni-directional acceptible !
Yes, you need a rooftop antenna. No, there is no onidirectional antenna that is appropriate for you.
Consider a HD7696P or HBU44
