Old 11-Sep-2012, 4:32 AM   #1
Gregg
Antenna choices for Oakton, VA
Hi folks,
I'm making the switch from cable to OTA. In fact, already disconnected cable and using a small indoor antenna temporarily.
I'm in Oakton, VA, which is about 15 miles west of 'TV hill' in DC. I've been hanging a small 10"x10" RCA flat square antenna out the 2nd story window facing east and able to pick up 1/2 a dozen channels (ABC, NBC, CBS, FOX, plus a few others). Quality is great when I get signal, terrible (e.g. artifacts/pixelization) when it's raining or other foul weather.
I'd like to have professionally mounted a good or great antenna so I can get the 'key-4' channels all the time and any others are a bonus. The challenge I'm struggling with is which antenna to buy.
I had been looking at the Channel Master 4228HD and the Winegard HD-8800. The confusion I'm getting is if either of these will actually allow me to pick up ABC, NBC, CBS and FOX given that the antennae are UHF only. If I read the signal analysis results correctly, it seems I WON'T be able to get the DC-based ABC and CBS station using these two antennae. Is that true?
Here's the link to my signal analysis results.
http://www.tvfool.com/?option=com_wr...5ed6b10582bee0
So, all that said, if the two above won't allow me to get the 'key-4' channels, what antenna recommendations do folks have for where I live? I would suspect at 15 miles, I won't need preamplifier.
A few key facts and desires:
- I live in the woods, 60' trees are everywhere (they named it Oakton for a reason)
- I'd prefer an antenna that is lease vurnable as possible to damage (again, living in the woods, any storm will thrown branches and twigs everywhere).
- Ideally something of quality that isn't going to break or rust in a year.
Gregg
Gregg is offline   Reply With Quote
Old 11-Sep-2012, 5:52 AM   #2
The following is a Teleview recommendation for broadecast Tv reception.
A Simple reception situation.
Above the roof install a Winegard HD7696P antenna aimed at about 76 degree magnetic compass direction.
For 1 tv connected use no splitter no amplifier.
For 2 Tv's connected use a common simple 2 way splitter , no amplifier.
For 3 or 4 Tv's connected use a Channel Master CM3414 distribution amplifier.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com/Tripods%200703/4712.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.channelmaster.com.
It is best mount the Tv antenna at a location that has the least amount to no amount of obstructions in the direction of reception.
Old 11-Sep-2012, 6:22 AM   #3
The following is a Teleview recommendation for Digital Broadcast Tv Reception.
For more strength and duribility.
Above the roof install a Antenna Direct , Clear Stream 4 and a Antennas Direct C5 antenna , both aimed at about 76 degree magnetic compass.
The C5 comes with a combiner to connect the CS4 and C5 together on to one coax down lead.
For 1 Tv connected use no splitter no amplifier.
For 3 or 4 Tv's connected use a CM3414 distribution amplifier.
_________________________________________________________
If your house has a chimney , can tie a , long , pole or pipe to the chimney as a temporary way of testing reception , can give a idea of how high or low will have to go for reception.
The more distance away the trees are in the direction of reception the better.
If there is a opening in the trees in the direction of reception , that's better.
___________________________________________________________________
