Old 9-Sep-2012, 9:17 PM   #1
Badger
Reception Issues
Hi all,
I ditched cable a few months back because I didn"t watch enough tv and it was getting expensive. I live on the second floor of an apartment and have an indoor antenna by a patio door that faces northeast. I have tried various antenna, but I keep having the same issue. Every time a car drives by my signal cuts out and the screen goes black for a few seconds. As you can imagine, this gets annoying especially on traffic heavy days. My antenna is connected directly into the tv with no splitters attached. I really only care about getting constant signal from the 4 major networks (ABC, NBC, CBS, and Fox).
A link to my report can be seen in the following link:
http://www.tvfool.com/?option=com_wr...5ed6fd4788773f
Any advise on things I can do to fix this issue would be greatly appreciated.
Thanks in advance. http://emacedgame.net/
Badger is offline   Reply With Quote
Old 10-Sep-2012, 12:59 AM   #2
The following is a Teleview recommendation for broadcast Tv reception.
The second floor balcony that faces north east.
If a antenna were out on the balcony , is there clearance to the south east to aim a antenna to the south east??
What directions does the street run that has the cars??
Are there any windows that face , south east , south??
________________________________________________
Try a Winegard FV-HD30 on the balcony , aimed at about 120 degree magnetic compass direction.
The best way to get the coax from the balcony to inside the apartment is a hole through the wall.
Here is another way. http://www.hollandelectronics.com , or at , http://www.solidsignal.com.
# 144823 flat antenna coax .
Also try the FV-HD30 in , south east , south , window.
Old 11-Sep-2012, 12:44 PM   #3
Badger
Yes there should be clearance to the southeast to point an outdoor antenna.
The street runs parallel to my window so it runs northwest-southeast and all of my Windows face the same northeast direction.
Is there a way to fix this using indoor antennas? I"m not sure that they would like me drilling a hole through the exterior wall. http://quapoker.net http://retrodbonus.org/ casino sydney
Old 11-Sep-2012, 4:04 PM   #4
It is amazing , the Resistance , to taking even simple action to get Tv reception.
There are no magic Tv antennas.
There are no magic reception situations.
_____
If there are any of those small satellite dishes on the outside , how do the coax cables get from the satellite dish to the receiver on the inside????
Through a hole through the wall????
And how does the cable tv company add a extra cable outlet to an other room??
Is it with coax on the outside of the building , and then the coax goes through a hole through the wall in to the room????
Did you read the part about the flat coax?? . The flat coax is not the first choice to get the coax from point A to point B.
As a test of reception , It is OK to run a coax through the - open - balcony door.
As you can see on the the tvfool radar map , The main groups of digital Tv stations are to the South East.
On the balcony , Above the balcony wall , aim the FV-HD30 to the South East.
Adjust the aim for best reception.
______________
_____
It is best to have the antenna at a location that has the least amount to no amount of obstructions to the South East.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , some times named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
