Old 13-Jan-2011, 1:19 PM   #1
Semokid
Semokid's Avatar
Cool Telescoping Mast?
Just wondering if anyone has a good reveiw or a negative one on the use of this type mast.I know that it would need to be guy wired well for support!
Semokid is offline   Reply With Quote
Old 13-Jan-2011, 3:35 PM   #2
Telescoping masts can do a great job if built well and used correctly.
Are you looking for a recommendation on what kind of mast to buy? Do you have a particular make/model in mind? Where will it be used?
Old 13-Jan-2011, 4:05 PM   #3
Semokid
Semokid's Avatar
Cool
No i do not have a brand or type as of yet,just wondered if this type of mast had any advantages or disadvantages over say the sectional type for outdoor use!
Old 16-Jan-2011, 2:57 AM   #4
http://www.3starinc.com has telescoping masts
Old 16-Jan-2011, 12:28 PM   #5
Semokid
Semokid's Avatar
Cool
Thank you for the link!
Old 17-Jan-2011, 11:51 PM   #6
Here is a way to put the location of your antenna 'link' in the Help With Reception part of tvfool. Using your correct address and a antenna height of 30 feet , make a radar plot. And at the top of screen you will see the address bar , the address bar is what has the , http:// . Copy every thing in the address bar starting with http://. on paper , wright on the paper the ---->exact<---- information in the address bar using block letters and block numbers. . Now go to the previous 3 that you put in the 'help with reception' part of tvfool. Delete 2 of them using the advanced function button. Now in the remaining 'help with reception' you click on the blue circle with the 2 link chain and you will see this , http://____________________________________. <---- put the complete address. And click on the button to insert it in the box where you ask your questions and give your information.
