Old 13-Jan-2011, 7:39 AM   #1
Coder
Question I need help finding the best antenna, please
http://www.tvfool.com/?option=com_wr...3cf4ff921f6118
I have two brand new HDTVs and want to ditch the satelite service. I live in a subdivision (single story house) in a wooded, semi mountainous area. I would like to be able to receive the Atlanta locals...wxia, wbs, waga, etc. Also, can I combine analog and digital tvs in different rooms. I have two digital and two analog tvs and would like to get all on the antenna. Any help for antenna selection would be greatly appreciated!
Cheers!
Coder is offline   Reply With Quote
Old 13-Jan-2011, 6:12 PM   #2
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
if you are concerned with the Atlanta stations only, you shouldn't need a rotator, however, if you add a rotator, you should also be able to see the Asheville, NC stations, as well.
I would use a Winegard HD-7698P and a preamplifier like a Channel Master Titan 7778 or an AntennaCraft 10G221 high-input preamplifier, and a rotator like a Channel Master 9521a rotator. You'll get plenty of TV reception if you do.
The preamplifier will allow you to power up to 4 TV sets if you use a good 4-way splitter. If you still have some non-digital TV sets, you can buy digital converters to allow those TV sets to see the new digital broadcasts. See the forum on digital tuners and converters for good information about digital tuner choices.
Here is a good installation guide to help you:
http://manuals.solidsignal.com/AntInstallGuide.pdf
Old 14-Jan-2011, 7:31 AM   #3
Coder
I will check it out. Thanks for the installation guide, that is very helpful as well.
Cheers
antenna recommendation
