Old 6-Sep-2012, 11:42 PM   #1
rohitranjan
Suggest an Antenna - Rockville, MD
I got few indoors ones but I get drop in signal. I can put one on my roof but wanted to get suggestions from you guys.
Here is report,
http://www.tvfool.com/?option=com_wr...e7793d89957f9b
Any suggestions for which antenna to opt? Any input/help is appreciated. I have absolutely no clue about these things so if you can point out muti direction or directional antenna with some input( pros/cons) and which cable to use then it will be a great help for me.
rohitranjan is offline   Reply With Quote
Old 7-Sep-2012, 5:51 AM   #2
An outdoor antenna should be able to do quite well.
A Winegard HD7000R or RCA ANT-751 are both capable antennas in the conditions shown on your report. The 7000 will offer reception of the two analog signals on real CH-4 & CH-6. The 751 is more compact, and is designed for reception of real CH-7 & up.
RG-6 cable sold at the big box home centers is just fine.
Old 7-Sep-2012, 9:15 AM   #3
The following is a Teleview recommendation for broadcast Tv reception.
Above the roof install a Winegard HD7000R antenna with no preamp , aimed at about 164 degree magnetic compass direction.
It is best to locate the antenna at a place that has the least amount to no amount of obstructions in the directions of reception.
The Tv Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Old 7-Sep-2012, 12:12 PM   #4
I second the RCA ANT-751 antenna recommendation. There is nothing on real channel 4 & channel 6 is a radio station.
