Old 5-Sep-2012, 1:50 PM   #1
Philgire
Antenna Recommendation in Wisconsin
Here is the station map generated from the wizard:
http://www.tvfool.com/?option=com_wr...e7797f829d2e81
I would like to pickup the most channels possible and will mount onto my roof.
Thanks for your time.
Philgire is offline   Reply With Quote
Old 6-Sep-2012, 2:23 AM   #2
The following is a Teleview - recommendation for broadcast Tv reception.
Antenna system # 1.
For reception of the Digital Tv station/channels in the Green and Yellow reception zones of the tvfool channel list to the north east.
Instal a Winegard HD7696P antenna with no preamp aimed at about 65 degree magnetic compass direction.
For 2 tv's connected use a common simple 2 way splitter.
For 4 Tv's connected use a common simple 4 way splitter.
It is best to install a Tv antenna at a location that has the least amount to no amount of obstructions in the direction of reception.
The Tv/s Must Channel Scan for the Digital Broadcast Tv stations/channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Old 6-Sep-2012, 3:04 AM   #3
The following is a Teleview - recommendation for digital broadcast Tv reception.
Antenna system # 2.
If you will like to try for reception of the Digital Tv stations/channels of the tvfool channel list to the south.
Above the roof install a Winegard HD9095P UHF antenna with a Winegard AP8275 preamp aimed at about 164 degree magnetic compass direction.
Most likely , WPXE-DT 40 ION Tv , WISN-TV 34 ABC , WCGV-TV 25 MyNetwork , WMVT 35 PBS , will most likely be received.
The only way to find out is try it.
For 1 tv connected use no splitter.
For 3 Tv's connected use a HFS-3D , 3 way splitter.
For 4 Tv's connected use a HFS-4D , 4 way splitter.
_________________________________________
The HD9095P UHF antenna , preamp , and All coax and splitters and etc. , is Not Connected to the other antenna system.
Antenna system #'s 1 and 2 are Separate antenna systems.
At each Tv location will be a Remote control A/B antenna coax switch.
http://www.radioshack.com , #15-1968 , or , http://www.mcmelectronics.com , #32-4425 .
Remote control A/B antenna switches are channel surfing friendly , press the button on the hand held remote control , change antenna systems and keep on channel surfing.
_________________
If you will like to add 2 more Digital Tv stations/channels , install a Winegard YA1713 VHF high band antenna aimed at about 313 degree magnetic compass for reception of , WSAW-TV channel 07 CBS and MyNetwork , WAOW channel 09 ABC and CW and This Tv.
Connect the HD9095P and YA1713 together with a UVSJ = UHF/VHF Separator/Joiner and connect the AP8275 preamp to the UVSJ to amplify both antennas.
The HD9095P and YA1713 connected this way are an extended larger antenna system # 2.
Old 6-Sep-2012, 3:44 AM   #4
The following is a Teleview recommendation for digital broadcast tTv reception.
I suggest receiving the north east group of Tv stations only to start with.
Old 6-Sep-2012, 1:36 PM   #5
Philgire
Thank you for all the help.
