Old 4-Sep-2012, 11:10 AM   #1
thedannyjane
PBS in Atlanta?
We have had a big box tv with a radio shack ears/loop antenna for 3 years and received Chs 2,5,8,11,17,30,46,69 w/o much problem.
We bought a flat screen this weekend and got a new amplified flat, RCA antenna.
Although the new antenna now picks up a dozen or so additional channels, neither it nor the old one now pick up ch 8 (PBS/GPB and a must have in our house). (all the other originally listed channels are fine, maybe better with the new attenna).
My signal map: http://www.tvfool.com/?option=com_wr...e7795e202e85ab
thedannyjane is offline   Reply With Quote
Old 4-Sep-2012, 5:23 PM   #2
The follwing is a Teleview - recommaendation for digital broadcast Tv reception.
A Simple reception situation.
Above the roof install a ANT751 antenna , with No preamplifier , aimed at about 290 degree magnetic compass direction.
http://www.solidsignal.com , has the ANT751 Antenna with a J Type Antenna Mount for low dollars.
For 1 Tv connection use splitter.
For 4 Tv's connected use a common simple 4 way splitter.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the transmissions travel through the air from the transmitting antenna to the receiving antenna.
Old 4-Sep-2012, 5:28 PM   #3
thedannyjane
I really would prefer an indoor antenna. I know an indoor antenna can receive the GPB signal because I had it for 3 years. But for some reason, its not working with my new tv?
(How much, typically, does it cost to install and wire a rooftop antenna to my tv?)
Old 4-Sep-2012, 6:17 PM   #4
The following is a Teleview - recommendation for digital broadcast Tv reception.
Use a Terk HDTVi indoor antenna aimed at about 290 degree magnetic compass direction.
Here is how to aim indoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
