Old 31-Aug-2012, 7:56 PM   #1
gruss306
Antenna Recomendations
Limited on placement of an antenna on roof.
Can put an antenna approx 20-25 ft above ground.
Any suggestions?
Gruss306
http://www.tvfool.com/?option=com_wr...e7794083476e7d
gruss306 is offline   Reply With Quote
Old 31-Aug-2012, 8:03 PM   #2
thom
bad url. try it again
thom is offline   Reply With Quote
Old 31-Aug-2012, 8:57 PM   #3
@gruss306, I believe I was successful repairing the TV Fool report link... Please verify it.
Welcome
Old 31-Aug-2012, 9:17 PM   #4
thom
lol, you're in what TV heaven looks like.
Can you explain what you mean by "Limited on placement of an antenna on roof"?
Would you prefer a smaller, lighter antenna (i.e. simplified mounting), or are there just a couple viable places you can mount it on the roof?
Old 31-Aug-2012, 10:01 PM   #5
All questions and answers about broadcast tv reception and More.
The following is a Teleview - Recommendation for Broadcast Tv Reception.
If the corrected , tvfool report is correct.
A Simple reception situation , Many Strong Signal Strength Easy To Receive Digital Broadcast Tv station/channels.
Above the roof install a ANT751 antenna with no preamplifier. aimed at about 270 degree magnetic compass direction , West.
http://www.solidsignal.com , has the ANT751 that comes with a J mount , $ Low dollars.
For 1 Tv connection use no splitter.
For 2 Tv connections use a common simple 2 way splitter.
For 3 Tv connections use a common simple 3 way splitter.
______________________
It is best to locate the ANT751 antenna at a location the has the least amount to no amount obstructions of reception.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com.
Old 31-Aug-2012, 11:52 PM   #6
If you are facing 80' Douglas Fir trees (as many here in Western WA do), you'll need to consider going with a larger antenna. A Winegard HD7694P or 7696 comes to mind.
Old 1-Sep-2012, 1:57 AM   #7
The following is a Teleview - Recommendation for Digital Broadcast Tv Reception.
Here is the Federal Antenna Law that says Yes you can , Install , Use , Maintain , Tv antennas above the roof in such a manner that you will have reliable reception.
There are No Size Restrictions for Tv antennas.
There are No Placement Restrictions , You can not be required to hide the antenna.
You can install the antennas in plain sight.
Hoa's , Housing Coven-nuts , and etc. are well aware of this Federal Antenna Law and they are aware that they Must Comply with the Federal Antenna Law.
http://www.fcc.gov/mb/facts/otard.html
