Old 26-Aug-2012, 6:51 AM   #1
mgtsmpsn
Which antenna zip 63822
I did not know how to add map info.
mgtsmpsn is offline   Reply With Quote
Old 26-Aug-2012, 7:03 AM   #2
newheart722
Zip 63822
mgtsmpsn,
Click on the "TV signal analysis" link at the top of the page, and fill in your address info. Then you will see a line that reads
/http://www.tvfool.com...etc... /
Copy and paste that line in your next post.
newheart722 is offline   Reply With Quote
Old 26-Aug-2012, 7:21 AM   #3
Tv Reception.
The following is a Teleview Tv Reception Recommendation.
Is this a , house , town home , condo , apartment , mobile home , motor home , or etc. ??
What floor , what is the top floor??
What directions do windows , patios/balconies face??
Use the Exact address to make the tvfool radar report.
Make the antenna height 25 feet.
Old 26-Aug-2012, 7:48 PM   #4
mgtsmpsn
Which antenna zipp 63822
ranch style house windows north south & east. 1 floor small town. I have HD tv and a small 12 inch tv in bedroom.
203 s. medler st. bernie, mo
Old 26-Aug-2012, 9:01 PM   #5
Tv Reception.
Based on the provided address , here is the tvfool radar plot map ,
http://www.tvfool.com/?option=com_wr...e7792e6487d93a.
Old 26-Aug-2012, 10:06 PM   #6
Tv Reception.
Here is a list of Digital Tv stations/channels that are in the Yellow reception zone.
KPOB-DT REAL Digital UHF channel 15 , virtual number (15.1) ABC.
KBSI REAL Digital UHF channel 22 , virtual number (23.1-2) FOX and MyNetwork.
WPSD-DT REAL UHF channel 32 , virtual number (6.1-2-3) NBC and RTV Retro Tv Network and Antenna Tv.
KFVS-DT REAL Digital VHF channel 12 , virtual number (12.1-2-3) CBS and The CW and Weather X.
For reception of these Easy to receive Digital Tv stations/channels install Above the roof a ANT751R antenna with no preamplifier aimed at about 50 degrees magnetic compass direction.
For 1 Tv connection use no splitter,
___________________________
I see no local PBS station.
The receivable distant PBS station signal strength is weak.
So to Reach Out for KTEJ REAL UHF channel 20 , virtual number (x) PBS.
Install a Separate antenna.
Above the roof install a Winegard HD9095P antenna with a Antennas Direct CPA-19 preamp , aimed at about 222 degrees magnetic compass direction.
For one Tv connection use no splitter.
For 2 Tv's connected use a HFS-2D , power passing 2 way splitter.
Buy the HFS splitter at , http://www.hollandelectronics.com or http://www.solidsignal.com.
_______________________________
The 2 antenna systems Will Not be connected to gather on to one coax.
The 2 antenna systems are Separate systems all the way to the Tv's locations where the 2 Separate antenna systems will be connected to a Remote control A/B antenna switch at each Tv location , http://www.radioshack.com , #15-1968 , or , http://www.mcmelectronics.com , #32-4425 .
Old 26-Aug-2012, 10:48 PM   #7
Tv Reception.
Here are some roof top antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com.
_______________
It is best to locate a antenna where there is the least amount or no amount of obstructions in the directions of reception.
____________
