Old 31-Dec-2010, 1:03 AM   #1
hd28vsb
Need advice on antenna setup TV Fool report included
Hope someone can give me some advice on antennas preamps etc . I have been pouring through post and have learned alot but want to be sure I do this right .
I am looking to drop my Directv and go OTA.
I am in a rural location. Nearest trees are to the E / NE and are 150 feet from antenna location . Trees are 50 feet tall . The TV Fool report was with a 20 foot antenna , 30 feet would be the max. I would want to go.
Here is the TV Fool report
http://www.tvfool.com/?option=com_wr...da326df2226fc5
Thank You
hd28vsb is offline   Reply With Quote
Old 31-Dec-2010, 2:33 AM   #2
Post a second radar map. Keep the first one , and give us a second one at 30 feet. . . .How many Tv's will be connected ?
Old 31-Dec-2010, 2:43 AM   #3
hd28vsb
30 feet report
Here is a second report at 30 foot.
http://www.tvfool.com/?option=com_wr...da323261457940
Old 31-Dec-2010, 4:29 PM   #4
Thank You
The easiest antenna system operationally would be a 91XG aimed at 4° and a Y10-7-13 aimed at 128°. Use a 7777 preamp in the separate VHF/UHF mode to add them together.
You'd get a full set of networks from the north and CBS from the SW. PBS and CW might work, try it first. If not consider either a rotator or a third or forth antenna with A/B/C switches.
Old 25-Feb-2011, 3:22 PM   #5
hd28vsb
Thank You Tower Guy
I followed your advice and went with the 91XG antenna and preamp.
Pulling in all the networks and PBS couldn't ask for better results.
