Old 21-Aug-2012, 6:03 PM   #1
stripenine
Rural antenna choice
I'm having a tough time picking an antenna that will work best in my situation. I'm in very rural North Carolina, on a mountainside, surrounded by trees. I'm currently using a homemade, DIY-type antenna. I'm able to pick up a few channels; ABC in HD as well as standard, WMYA, and three PBS channels. I would like to be able to pull in NBC and CBS if at all possible. I'm pretty flexible on installation options; attic, roof, even a tall tree if need be. Here's the link to my report:
http://www.tvfool.com/?option=com_wr...99008ec90dc792
Any help would be greatly appreciated.
W.
stripenine is offline   Reply With Quote
Old 21-Aug-2012, 9:13 PM   #2
signals unlimited
Your report is for 20'
Since you are flexable on mounting options, extra height may make a huge difference.
Please run your report at 40' and 60'
Old 21-Aug-2012, 9:16 PM   #3
Tv Reception.
To see if signal strengths improve with more antenna height , please make 2 more tvfool radar plot map reports , 40 and 60 feet antenna heights.
The Digital Tv stations/channels that you are installing a antenna to receive are.
WLOS REAL Digital VHF channel 13 , virtual number (13.1) ABC and MyNetwork.
WUNF-TV REAL Digital UHF channel 25 , virtual number (x) PBS.
W08AO REAL Digital VHF channel 08 , virtual number (x) CBS and Me Tv.
W23BQ REAL Digital UHF channel 23 , virtual number (x) Religion.
WUNW REAL Digital UHF channel 27 , virtual number (x) PBS.
W08BP REAL Digital VHF channel 08 , virtual number (x) CBS and Me Tv.
W11AU-D REAL Digital VHF channel 11 , virtual number (x) NBC and This Tv.
_________________________________
W02AG , W08AO , WSPA , W08BP , are all the same CBS and Me Tv.
WUNF , WUNW , W19HK-D , are the same PBS.
http://www.rabbitears.info/market.ph...callsign=69389.
______________________________________
Install a Winegard HD7698P antenna with a Antennas Direct CPA-19 preamp , aimed at about 65 degree magnetic compass direction.
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/Tripods%200703/4712.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com/tree_adjust.html , http://www.ronard.com.
Here is a , Light Weight Aluminum , Free standing , No guy wires , Lay Over Tower , Do antenna mounting and adjustments standing on the ground. http://www.palcoelectronics.com/pe300.aspx.
_______________________________________
For 1 Tv connection use no splitter.
For 2 Tv connections use a , HFS-2D , 2 way splitter.
Fo 3 Tv's connected use a , HFS-3D , 3 way splitter.
http://www.hollandelectronics.com or http://www.solidsignal.com.
Old 21-Aug-2012, 9:33 PM   #4
stripenine
My report at 40' is
http://www.tvfool.com/?option=com_wr...990087c94563d9
and at 60'
http://www.tvfool.com/?option=com_wr...990069c1f202b0
I wanted to add that we do have a pretty clear LOS to the southeast, but a ridge essentially blocks everything to the west and north.
Thanks again for all the help. I'll take a look at the Winegard.
W.
Old 21-Aug-2012, 10:52 PM   #5
Tv Reception.
The Tv stations that you will receive are from about 57 to 102 degree magnetic compass direction , east north to a little past east , east and a little south.
Form 20 to 40 feet there is not much improvement in signal strength , even so it Is Better to have the antenna higher then 20 feet.
There is a little better improvement of signal strength at 60 feet.
If this were my house I would shoot for 40 feet or higher.
I am changing the antenna to a bigger antenna , HD7698P antenna , a bigger antenna means more reception.
At first I recommended a HD7696P antenna because I thought you might put the antenna in a pine tree , the HD7698P is smaller and would not whip around as much in a tree as a HD7698P antenna would.
So now that you have a clearer view to the east north to east south. I am recommending the HD7698P antenna.
Mount the HD7698P antenna up high and I believe the listed Tv stations will be received.
It is best to install/mount the antenna where there is the least amount to no amount of obstructions in the direction of reception.
Old 21-Aug-2012, 11:15 PM   #6
Tv Reception.
One more issue.
W47DY REAL Digital UHF channel 47 , FOX TV.
Is signal strengths of minus - 11.8 NM(dB) at 20 feet antenna height.
Minus -10.1 NM(dB) at 40 feet antenna height.
Minus -7.5 NM(dB) at 60 feet antenna height.
60 feet is the best by a small amount.
The signal strength numbers put the reception with in reach , it will be interesting to see how the reception works out.
I think the station will be reliably received.
Old 21-Aug-2012, 11:16 PM   #7
stripenine
Great. Thank you very much for your help. Once I get everything installed, I'll post a reply to let you guys know the results. Thanks!
W.
