The HD7697P antenna is $89.99 at solidsignal.
The HD7082P antenna is $70.99 at solidsignal.
___________________________________________
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels" or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
It is best to locate the HD7082P antenna at a location that has the least amount to no amount of obstructions in the direction of reception.
_________________
These Tv digital Tv stations are Strong Signal Strength and will most likely be received by the HD7082P antenna even though the antenna is not aimed at them.
WMBC UHF digital channel 18 , IND.
http://en.wikipedia.org/wiki/WMBC-TV
WNJN - WNJB - and etc. , are all the same PBS ,
http://en.wikipedia.org/wiki/WNJB-TV.
______________
WNET-DT VHF channel 13 is at the front of the antenna and is also part of the same PBS.
And as for WNBC REAL UHF Digital channel 28 , it is transmitting on UHF 28.
The old Analog channel VHF channel 4 is no longer being transmitted , the number 4 is now a virtual number.
During the Analog to Digital transition of June 2009 , Many - but not all - Tv stations moved out of the VHF low band channels 2 thru 6 , to the higher band channels of 7 thru 51.
