Old 19-Aug-2012, 10:16 PM   #1
Marken88
Starting From Scratch
http://www.tvfool.com/?option=com_wr...99003cc6709198
After 6 years, we're dumping Dish. Need to go OTA and we will need everything.
Antenna would be about 20-25' on a pole outside.
Interested in the Green Bay area channels which are about 40 miles NE of us.
Any suggestions to get us going would be appreciated.
Ken
Marken88 is offline
Old 20-Aug-2012, 1:39 AM   #2
Tv Reception.
The tvfool report says resolved to street level only , can you make a report with exact address??
With the antenna at 25 feet height.
Old 20-Aug-2012, 1:47 AM   #3
Marken88
Thanks for the reply.
We live on a lake and I put in my address, and the report is what came up. How can I change it?
There will be 2 televisions hooked up.
Marken88 is offline
Old 20-Aug-2012, 4:50 AM   #4
Tv Reception.
Go the tvfool home page.
Click on the >>Start MAPS<<.
Move the pointer to your location.
Make the antenna height 25 feet.
Make a tvfool radar plot map.
Old 20-Aug-2012, 4:08 PM   #5
Marken88
http://www.tvfool.com/?option=com_wr...99005f0d88ef01
This is what came up after I hit make radar plot. Is this what your looking for?
Ken
Marken88 is offline
Old 20-Aug-2012, 8:17 PM   #6
Tv Reception.
A Simple reception situation.
For reception of the Digital Tv stations/channel to the north east at about 30 degree magnetic compass direction.
Above the roof install a Winegard HD9095P antenna aimed at about 30 degree magnetic compass direction.
Here is how aim antennas , http://www.kyes.com/antenna/pointing/pointing.html.
As always , tres and tree leaves do a real fine job of , reflecting , reducing , blocking , Tv reception and so do buildings and other obstructions.
It is best to locate the antenna at a location where there is the least amount to no amount of obstructions in the direction of reception.
Old 20-Aug-2012, 8:46 PM   #7
Marken88
Once again, thanks for the reply.
One question though.
I see this is a UHF only antenna. Our Fox channel, 11.1, is a VHF Hi channel.
Will it receive this channel also? Need my Nascar fix
Ken
Marken88 is offline
Old 20-Aug-2012, 8:57 PM   #8
Tv Reception.
You are correct.
Install a Winegard HD7696P antenna , not the HD9095P antenna.
Copyright ©2025 TV Fool, LLC
