Old 16-Aug-2012, 8:45 PM   #1
rmp74006
New to OTA, Need Antenna/Set Up Recommendation
Here is my signal analysis:
http://www.tvfool.com/?option=com_wr...9900e00ea812ac
Looking for antenna recommendations from those of you who have some experience & knowledge of best antenna brands/types. Many thanks!
rmp74006 is offline   Reply With Quote
Old 16-Aug-2012, 9:35 PM   #2
Tv Reception.
This is a different location then your other post.
Is this a , house , town home , condo , mobile home , motor home , or , etc.??
If an apartment or etc. , what floor?? , What is the top floor??
What directions are windows?? What directions are patios/balconies??
Make a second tvfool radar report with the antenna height 25 feet.
Old 16-Aug-2012, 10:23 PM   #3
rmp74006
Yep - we recently moved to South-Central Arkansas. We will be in a rental house, so my options for outdoor antenna may be limited to a free-standing pole. If possible, I would prefer at least trying an attic antenna, although I know I am greatly reducing signal strength. It is likely just for 1 HD TV, although I may want to consider option for adding a split to an older TV.
Old 17-Aug-2012, 4:10 AM   #4
Tv Reception.
The first 2 Digital Tv stations are what will be received with a antenna in the attic , If that is Ok with you then install a Winegard HD7696P antenna with a Channel Master CM7778 preamp in the attic aimed at about 12 degree magnetic compass direction.
___________________________
For reception of more then 2 digital Tv stations install a Winegard HD7696P antenna with a Winegard AP8700 preamp aimed at about 12 degree magnetic compass direction.
Above the roof or at a location that is Up High free and clear of obstructions , as always trees and tree leaves do a real fine job of , reducing or blocking reception and so do buildings and other obstructions.
Here are 2 antenna mounts that do not make holes in the roof , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html, buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box.
http://www.3starinc.com , has push up antenna mounting poles.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com , http://www.channelmasterstore.com.
__________
For 2 Tv's connected use a HFS-2D , 2 way splitter.
Buy the HFS splitter at , http://www.hollandelectronics.com , also at , http://www.solidsignal.com.
___________
