Old 15-Aug-2012, 3:32 AM   #1
C970
Newbie seeking help with antenna
Hello,
I am very new to the outdoor antenna arena and was hoping to get some advice on what type of antenna I should install.
my goal is to install the antenna outside and run it through an unused cable outlet in my home. I do have trees around my home about 100 feet away from where I was looking to install it.
this is my TV fool report:
any suggestions or guidance would be greatly appreciated.
http://www.tvfool.com/?option=com_wr...99005e95cf5e57
C970 is offline   Reply With Quote
Old 15-Aug-2012, 5:19 AM   #2
Tv Reception.
A simple reception situation.
To receive the Denver Digital Tv stations/channels.
Above the Roof install a Winegard HD7696P antenna , with no antenna amplifier , aimed at about 170 degree magnetic compass direction.
_____________________________________________________
Old 15-Aug-2012, 6:24 AM   #3
C970
Thanks for the great information. I never thought purchasing an antenna would be so overwhelming. Glad I found this site.
