Old 11-Aug-2012, 4:10 AM   #1
coolkoalabr
Question Please help me choose an antenna
http://www.tvfool.com/?option=com_wr...9900942c1df7d1
Hello,
I live in a 1-story house and have tried all the indoor antennas from Walmart (bunny-ear antenna, some flat rectangle shaped antennas) but none of them are able to pick up NBC network (channel 11). I was unable to watch the Olympics
I would like to be able to watch NBC, ABC, CW, Ind (KTSF 26.1), PBS. I was thinking about buying http://www.amazon.com/RCA-ANT751R-Ou.../dp/B0024R4B5C or http://www.amazon.com/AntennaCraft-2...pr_product_top
Also, this is my TV http://www.newegg.com/Product/Produc...82E16889234047
Any suggestions or advice would be great. Thank you for your help
coolkoalabr is offline   Reply With Quote
Old 11-Aug-2012, 4:23 AM   #2
Tv Reception.
Above the roof install the ANT751 antenna (no antenna amplifier required) aimed at about 315 degree magnetic compass direction.
________________________________________________________________________________ ________
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com.
The Tv/s Must Channel Scan for the digital Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna channels" in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
